hi
iam running a docker container with syncthing.
there is a sync folder with activated file versioning.
i created a symlink from …/Recycle/Test to Test/.stversions
now the versionirer is broken.
if the files will delete or changed its just nothing hapening.
the files will restore if i click to scan the folder.
there are no errors in the logfiles.
root@odroidxu4:/sharedfolders/Syncthing/Test# ls -l -a
-rw-r–r-- 1 user1 911 22413 Feb 4 14:35 Test.pdf
drwxr-xr-x 2 user1 911 4096 Feb 3 13:14 .stfolder
-rw------- 1 user1 911 0 Feb 3 13:15 .stignore
lrwxrwxrwx 1 user1 911 37 Feb 4 13:59 .stversions -> /sharedfolders/Syncthing/Recycle/Test
root@odroidxu4:/sharedfolders/Syncthing/Recycle# ls -l -a
drwxrwxr-x 3 user1 users 4096 Feb 4 14:33 .
drwx------ 6 user1 911 4096 Feb 5 05:17 …
d----w–w- 2 user1 911 4096 Feb 4 14:33 Test
If this is inside a docker container, the symlink will probably be interpreted in that context. Inside the container there is probably no /sharedfolders?
/sharedfolders/Syncthing:/sharedfolders/Syncthing
this works but not 100%
if i delete files or change they folow to
/Recycle/Test folder
but the versionirer has no acess to there
if i click on the button there is no data
i mean the Versions in the syncthing gui for restaration of the files.
root@odroidxu4:/# docker exec syncthing ls -l -a /sharedfolders/Syncthing/Test/
total 16
drwxrwxrwx 3 abc abc 4096 Feb 5 09:10 .
drwx------ 7 abc abc 4096 Feb 5 11:35 …
drwxr-xr-x 2 abc abc 4096 Feb 5 08:56 .stfolder
-rw------- 1 abc abc 0 Feb 5 09:02 .stignore
lrwxrwxrwx 1 root root 38 Feb 5 09:10 .stversions -> /sharedfolders/Syncthing/Recycle/Test/
-rw-r–r-- 1 abc abc 31 Feb 5 09:10 Test2.txt
root@odroidxu4:/# docker exec syncthing ls -l -a /sharedfolders/Syncthing/Test/.stversions
lrwxrwxrwx 1 root root 38 Feb 5 09:10 /sharedfolders/Syncthing/Test/.stversions -> /sharedfolders/Syncthing/Recycle/Test/
root@odroidxu4:/#
whats wrong ? i dont understand it. the deleted/changed files are in the linked folder
root@odroidxu4:/# docker exec syncthing ls -l -a /sharedfolders/Syncthing/Recycle/Test
total 12
drwxrwxrwx 2 abc abc 4096 Feb 5 10:02 .
drwxrwxr-x 3 abc 100 4096 Feb 4 14:33 …
-rw-r–r-- 1 abc abc 20 Feb 5 09:05 Test2~20190205-091058.txt
-rw-rw-r-- 1 abc 100 0 Feb 5 09:02 Test~20190205-090316.txt
root@odroidxu4:/#
It’s one of two things, either you have the start end dates bug that sets the filtering dates to some strange values preventing items from showing in the UI, or version restoration ui does not follow symlinks.
Also, please use triple backticks ""` to format your console output as otherwise it’s unreadable on mobiles.
root@odroidxu4:/sharedfolders# cd Test2/
root@odroidxu4:/sharedfolders/Test2# ls -l -a
total 8
drwxr-xr-x 1 user1 911 76 Feb 5 21:07 .
drwxr-xr-x 1 user1 users 134 Feb 5 21:03 ..
drwxr-xr-x 1 user1 911 0 Feb 5 21:02 .stfolder
-rw------- 1 user1 911 0 Feb 5 21:07 .stignore
lrwxrwxrwx 1 root root 16 Feb 5 21:06 .stversions -> /sharedfolders/r
-rw-r--r-- 1 user1 911 51 Feb 5 21:07 Test2.txt
root@odroidxu4:/sharedfolders/Test2# cd .stversions
root@odroidxu4:/sharedfolders/Test2/.stversions# ls -l -a
total 4
drwxr-xr-x 1 user1 users 50 Feb 5 21:07 .
-rw-r--r-- 1 user1 911 44 Feb 5 21:06 Test2~20190205-210737.txt
ok it works on a lower level.
i think the versioner is broken. there is no way to select a date.
and a manual input in the textbox make a 1970/… - 1970/…
