I’m a new user to OMV and Syncthing. I was able to get syncthing to work peer to peer as a test, but unable to get it to work in Docker.
I’m a gui user only, unless I have pretty clear directions.
I am able to create a folder on the NAS, and it populates with a Syncthing folder, but none of the folder content I expected.
I suspect the problem is in the volume mapping and I have two lines one for config and another for files. I have tried relative as well as absolute reference and neither help me get any further than where I am.
Here is my stack:
container_name: syncthing
hostname: syncthingonbeelink #optional
environment:
- PUID=1000
- PGID=100
- TZ=US/Eastern
volumes:
- xxxxxxx039a/data/appdata/config:/config
- xxxxxxx39a/data/syncthing/myfiles:/syncthing/myfiles
ports:
- 8384:8384
- 22000:22000/tcp
- 22000:22000/udp
- 21027:21027/udp
restart: unless-stopped
The appdata folder has a relative path of data/appdata/ the myfiles folder has a relative path of data/syncthing/myfiles
Under Compose services I have myfiles in the Compose Files section, and the appdata in the Data section.
Any suggestions would be appreciated. thanks, Scott
