The Device ID doesn’t say anything, why should we not use the distributed DNS system (with own DNS servers) to have a discosrv coupled with the strength of internet caching. I had an idea
TXT record
Prefix with st
ID of property
0: <Device ID (63 char string)>
1: <Device ID (63 char string)>
Server/NAS record
nas.xor-gate.org. 86205 IN TXT "st 0 PLO5DGO-VYXVWJY-4IE3JAB-7UDLNBH-BG4PKZA-FA4F2ML-GQVASQM-APPL3QG"
User instance on a system could become: jerry@nas.xor-gate.org resolves uses the record:
jerry.nas.xor-gate.org. 86205 IN TXT "st 1 jerry PLO5DGO-VYXVWJY-4IE3JAB-7UDLNBH-BG4PKZA-AB4F2ML-GQVASQM-APPL3QG"
This is just a idea with rough edges to share with you all.
I’m not sure I understand the point? This is a way of discovering the device ID for someone associated with a domain, so someone can bombard you with “Accept this device” requests? However they won’t know any of your folder IDs, so it’s not enough to actually share anything?
What if you’re behind corporate DNS servers that do not answer to TXT queries?
The value add here is that you don’t need to memorise IDs? How often do you need to add a device? You could just have a TXT record you can dig whenever you forget it that returns you the ID.
How many users actually have the capability to create txt records?
The idea itself is not bad, but it’s probably easier to add some sort of name aliasing and a sense of ownership into the vanilla discovery than to ask people to use DNS.
@AudriusButkevicius I totaly agree on your points. I have seen public internet in a train which won’t relay any SSHFP records. Syncthing is great, it should not become a “dropbox” replacement but current user-base are mostly tech people. Security and user-friendlyness are choices but I like the idea just to use an easy to remember alias (e.g name@domain) with my Device ID. This can also be implemented in a more advanced discovery with trusted/signed chains of key-values with the device id public part of the cert (e.g DHT).
It is indeed true people can DDOS on your syncthing instance because brute force on aliases (e.g with a domain) is easier than DDOS on the list of all possible device ids.
Something similar was proposed before, albeit different and more advanced, using SRV or even A records and DNSSEC for signing/verifying advertisements etc.
I had a thing written using miekg/dns, but I hit fragmentation issues, but that was for a different problem. Dns over https is essentially what we have now, just our addresses are device ids.
I could see a point in being able to add a device as either device ID or address (DNS or IP). If an address was entered you’d get to confirm/accept the device ID on first connect. Potentially in that case a TXT or SRV record could point out the correct device ID and you could skip the confirmation step.
In the case you want to add devices based on their “(pseudo)mail adres” we should hash with salt e.g {SSHA256} to prevent pushing semi-private information in public registries like DNS. Just like ssh known_hosts is able to be hashed for leaking hostnames.
