If both ends have been up twenty minutes shouldn’t they have found each other by now ?
I know I have asked this before when ends took days then it miraculously started working after my posting. (Also that I should try to move to my own hostname which I will work at now.)
Discovery happens every time devices try to connect, which should be every few minutes. If you can see ip addresses of the other device in the ui, discovery is working (also we show discovery status). The fact that they cannot connect is probably an issue with the networks they are in/firewalls and not discovery.
