Hi!
This is my first post on the forum, so let’s start with saying “thanks” for the very useful software that you created for the community!
I’m playing a bit with Syncthing. Currently I’m syncing a few files and also my Firefox and Thunderbird profiles across Windows and Linux clients, and syncing photo’s taken by my Android phone to my home server. Works just great. Firefox (and TB) needed a few ignore lines, would be great if the ignore settings would be synced as well, but I saw that is still on the radar for the future.
I have installed a discovery server and a relay, and I’m running them on a server behind NAT (on different KVM virtual machines). They are constricted to my “island”, no joining of other (default) discovery servers and relay pools. So far so good. Also set up port forwards on the router and matching internal and external DNS names.
Now my current issue. When using my laptop outside my local network, it connects to the discovery server, but not to the other syncthing instances running om my local network. Which makes sense, because the local instances announce themselves to the discovery server with their local IP address. My relay did not help much (it does connect to the relay from outside, after a while, but did not use it to connect to the client behind the NAT).
I “solve” this by specifying the device URL using the full DNS name and port, but that defeats the whole idea of running a discovery server.
Is there anything I can do to make this automagically work? I did not find a solution by reading the documentation.
If there is no real solution, maybe for the future these options might be considered:
- Add an option for the local syncthing instance to add something similar to “listenAddress”, like “discoAddress”, to announce to the discovery server.
- Add an option to the discovery server to try to reverse lookup the hostname for the connecting clients, and to announce that hostname (if found) to other clients. (Assume no port number change.)
The above would work if there is an internal DNS configured that matches external DNS. I especially would like the second option, as it just works if there is an internal DNS and different port numbers are configured for different syncthing instances and forwarded on the NAT router. Even if all instances would use the same port number, then it could work as TLS https connections contain host information (?) to a reverse proxy like squid or sslh could maybe do the trick.
Regards, Evert Mouw
