Discovery Failures 14 January 2026
Hi!
I had discovery failures, from Armenia:
The following methods are used to discover other devices on the network and announce this device to be found by others:
Some discovery methods could not be established for finding other devices or announcing this device:
Failure to connect to IPv6 servers is expected if there is no IPv6 connectivity.
They are Global Failure, or not?
Please, help :slight_smile:
Regards.
You have one failure accompanied by a message explaining why that might be expected depending on the fact if your ISP has IPv6.
