Hello! I’ve been having some trouble with Syncthing between my desktop and a remote VPS hosted in Digital Ocean running latest Ubuntu 18. It seems to be disconnecting and reconnecting constantly. I have found a few posts that are similar but the fixed from those haven’t worked for me, specifically these two topics, [1] and [1]
Here’s the relevent bit of the logs as this is repeated over and over.
[G4SBK] 17:54:56 INFO: Established secure connection to FV2PGYC at 192.168.1.187:22000-000.000.000.000:45544/tcp-server/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[G4SBK] 17:54:56 INFO: Device FV2PGYC client is "syncthing v0.14.43-ds1" named "remote host" at 192.168.1.187:22000-000.000.000.000:45544/tcp-server/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[G4SBK] 17:55:11 INFO: Connection to FV2PGYC at 192.168.1.187:22000-000.000.000.000:45544/tcp-server/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 closed: reading length: read tcp 192.168.1.187:22000->000.000.000.000:45544: wsarecv: An existing connection was forcibly closed by the remote host.
[G4SBK] 17:55:15 INFO: Established secure connection to FV2PGYC at 192.168.1.187:22000-000.000.000.000:45730/tcp-server/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[G4SBK] 17:55:15 INFO: Device FV2PGYC client is "syncthing v0.14.43-ds1" named "remote host" at 192.168.1.187:22000-000.000.000.000:45730/tcp-server/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[G4SBK] 17:55:18 INFO: Connection to FV2PGYC at 192.168.1.187:22000-000.000.000.000:45730/tcp-server/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 closed: reading length: read tcp 192.168.1.187:22000->000.000.000.000:45730: wsarecv: An existing connection was forcibly closed by the remote host.
I’ve tried the usually suspects, reboots, checked internet connection, checked firewall and AV, pausing and un-pausing, reinstalling on both Windows desktop and Ubuntu, not behind a firewall. Not sure where to go next.
Here are the logs from my Synctrazor, edited to remove IP https://pastebin.com/B2JzwPu1
Here is the log from the remote server [1]
Syncthing remote server web UI, [1]
Please let me know if there is anything else I can post to get this working! Thank you
[1] Links here new user restrictions, https://pastebin.com/3BfBULtj
