lilp69
(lilp)
September 18, 2023, 2:02pm
1
Hello,
I’m on v1.24.0 Linux, with two shares folders. Since one week, after I reboot my own server, I can’t succeed to connect my two devices.
They’re still in disconnect state.
Here some log, hope help :
2023-09-18 15:56:02 failed to connect to XxX 30
2023-09-18 15:56:02 dialing XxX quic://LanIP:22000 prio 40
2023-09-18 15:56:02 dialing XxX quic://WanIP:22000 prio 40
2023-09-18 15:56:02 dialing XxX quic://[XxX]:22000 prio 40
2023-09-18 15:56:02 dialing XxX quic://[XxX]:22000 error: dial: INTERNAL_ERROR (local): write udp [::]:22000->[XxX]:22000: sendmsg: cannot assign requested address
2023-09-18 15:56:07 dialing XxX quic://WanIP:22000 error: dial: timeout: no recent network activity
2023-09-18 15:56:07 dialing XxX quic://LanIP:22000 error: dial: timeout: no recent network activity
2023-09-18 15:56:07 failed to connect to XxX 40
2023-09-18 15:56:07 Next connection loop in 20s
2023-09-18 15:56:27 Connection loop
2023-09-18 15:56:27 Resolved device XxX addresses: [quic://LanIP:22000 quic://WanIP:22000 quic://[XxX]:22000 relay://49.12.93.194:22067/?id=XxX tcp://LanIP:22000 tcp://WanIP:22000 tcp://[XxX]:22000]
2023-09-18 15:56:27 Not dialing XxX via relay://49.12.93.194:22067/?id=XxX as it’s not time yet
2023-09-18 15:56:27 Not dialing XxX via tcp://LanIP:22000 as it’s not time yet
2023-09-18 15:56:27 Not dialing XxX via tcp://WanIP:22000 as it’s not time yet
2023-09-18 15:56:27 Not dialing XxX via tcp://[XxX]:22000 as it’s not time yet
2023-09-18 15:56:27 dialing XxX quic://LanIP:22000 prio 40
2023-09-18 15:56:27 dialing XxX quic://WanIP:22000 prio 40
2023-09-18 15:56:27 dialing XxX quic://[XxX]:22000 prio 40
2023-09-18 15:56:27 dialing XxX quic://[XxX]:22000 error: dial: INTERNAL_ERROR (local): write udp [::]:22000->[XxX]:22000: sendmsg: cannot assign requested address
2023-09-18 15:56:32 dialing XxX quic://LanIP:22000 error: dial: timeout: no recent network activity
2023-09-18 15:56:32 dialing XxX quic://WanIP:22000 error: dial: timeout: no recent network activity
2023-09-18 15:56:32 failed to connect to XxX 40
2023-09-18 15:56:32 Next connection loop in 20s
2023-09-18 15:56:52 Connection loop
2023-09-18 15:56:52 Resolved device XxX addresses: [quic://LanIP:22000 quic://WanIP:22000 quic://[XxX]:22000 relay://49.12.93.194:22067/?id=XxX tcp://LanIP:22000 tcp://WanIP:22000 tcp://[XxX]:22000]
2023-09-18 15:56:52 Dialer for relay://49.12.93.194:22067/?id=XxX: unsupported protocol: disabled by configuration
2023-09-18 15:56:52 dialing XxX tcp://[XxX]:22000 prio 30
2023-09-18 15:56:52 dialing XxX tcp://WanIP:22000 prio 30
2023-09-18 15:56:52 dialing XxX tcp://LanIP:22000 prio 30
2023-09-18 15:56:52 Dialing reuse result tcp [XxX]:22000: dial tcp [::]:22000->[XxX]:22000: connect: cannot assign requested address
2023-09-18 15:56:52 Dialing non-reuse result tcp [XxX]:22000: dial tcp [XxX]:22000: connect: cannot assign requested address
2023-09-18 15:56:52 dialing XxX tcp://[XxX]:22000 error: dial tcp [XxX]:22000: connect: cannot assign requested address
bt90
(Bt90)
September 18, 2023, 2:45pm
2
Did you hardcode the listening address? Sounds like your server got a new IP after the reboot.
lilp69
(lilp)
September 18, 2023, 2:48pm
3
I use device ID to connect my two devices
Do you have a non-standard listen address configured? Are you using some sort of VPN?
Syncthing tries to connect out on the same address it is listening on, and seems it is not allowed.
bt90
(Bt90)
September 19, 2023, 4:57am
6
The error might be caused by dialing a public IPv6 on a host without a GUA IPv6. But that still doesn’t explain why it’s not working for IPv4.
lilp69
(lilp)
September 19, 2023, 7:04am
7
Maybe, I needed to reboot my internet box.
How can I see Syncthing dialing with ipv6?
bt90
(Bt90)
September 19, 2023, 7:16am
8
Could you post the logs and only redact parts of the IPs?
lilp69
(lilp)
September 19, 2023, 7:49am
9
Here we go
2023-09-18 16:10:51 My ID: 7UYSQAK-xxx
2023-09-18 16:10:52 Single thread SHA256 performance is 1493 MB/s using minio/sha256-simd (364 MB/s using crypto/sha256).
2023-09-18 16:10:53 Hashing performance is 899.61 MB/s
2023-09-18 16:10:53 Device 3YCP6SQ-xxx send rate limit is 20000 KiB/s, receive rate limit is 20000 KiB/s
2023-09-18 16:10:53 Overall send rate limit is 20000 KiB/s, receive rate limit is 20000 KiB/s
2023-09-18 16:10:53 Rate limits do not apply to LAN connections
2023-09-18 16:10:53 Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-xxx
2023-09-18 16:10:53 Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-xxx
2023-09-18 16:10:53 Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-xxx
2023-09-18 16:10:53 Ready to synchronize “US-Movies” (hm3ek-2xzpp) (sendonly)
2023-09-18 16:10:53 …
2023-09-18 16:10:53 QUIC listener ([::]:22000) starting
2023-09-18 16:10:53 TCP listener ([::]:22000) starting
2023-09-18 16:10:53 Ready to synchronize “US-TvShows” (ymeru-qdgcj) (sendonly)
2023-09-18 16:10:53 GUI and API listening on [::]:8384
2023-09-18 16:10:53 Access the GUI via the following URL: http://127.0.0.1:8384/
2023-09-18 16:10:53 My name is “Ultra Seedbox”
2023-09-18 16:10:53 Device 3YCP6SQ-xxx is “Proxmox” at [dynamic]
2023-09-18 16:10:54 Completed initial scan of sendonly folder “US-Movies” (hm3ek-2xzpp)
2023-09-18 16:10:56 Completed initial scan of sendonly folder “US-TvShows” (ymeru-qdgcj)
2023-09-18 16:11:03 quic://0.0.0.0:22000 detected NAT type: Symmetric NAT
2023-09-18 16:11:07 Detected 1 NAT service
2023-09-18 16:53:24 Ready to synchronize “US-Movies” (hm3ek-2xzpp) (sendonly)
2023-09-18 16:53:24 Restarted folder “US-Movies” (hm3ek-2xzpp) (sendonly)
2023-09-18 16:53:24 Ready to synchronize “US-TvShows” (ymeru-qdgcj) (sendonly)
2023-09-18 16:53:24 Restarted folder “US-TvShows” (ymeru-qdgcj) (sendonly)
2023-09-18 16:53:27 Completed initial scan of sendonly folder “US-Movies” (hm3ek-2xzpp)
2023-09-18 16:53:30 Completed initial scan of sendonly folder “US-TvShows” (ymeru-qdgcj)
2023-09-18 16:53:51 Device 3YCP6SQ-xxx send rate limit is 20000 KiB/s, receive rate limit is 20000 KiB/s
2023-09-18 16:53:51 Ready to synchronize “US-Movies” (hm3ek-2xzpp) (sendonly)
2023-09-18 16:53:51 Restarted folder “US-Movies” (hm3ek-2xzpp) (sendonly)
2023-09-18 16:53:51 Ready to synchronize “US-TvShows” (ymeru-qdgcj) (sendonly)
2023-09-18 16:53:51 Restarted folder “US-TvShows” (ymeru-qdgcj) (sendonly)
2023-09-18 16:53:51 Completed initial scan of sendonly folder “US-Movies” (hm3ek-2xzpp)
2023-09-18 16:53:52 Completed initial scan of sendonly folder “US-TvShows” (ymeru-qdgcj)
2023-09-18 19:43:17 Listen (BEP/tcp): TLS handshake: read tcp 172.17.1.75:22000->167.248.133.39:32892: read: connection reset by peer
2023-09-18 19:43:18 Peer at 172.17.1.75:22000-167.248.133.39:55844/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P30 did not negotiate bep/1.0
2023-09-18 19:43:18 Got peer certificate list of length 0 != 1 from peer at 172.17.1.75:22000-167.248.133.39:55844/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P30; protocol error
2023-09-18 19:43:19 Peer at 172.17.1.75:22000-167.248.133.39:52212/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P30 did not negotiate bep/1.0
2023-09-18 19:43:19 Got peer certificate list of length 0 != 1 from peer at 172.17.1.75:22000-167.248.133.39:52212/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/WAN-P30; protocol error
2023-09-18 19:43:20 Listen (BEP/tcp): TLS handshake: tls: first record does not look like a TLS handshake
2023-09-18 19:43:21 Listen (BEP/tcp): TLS handshake: read tcp 172.17.1.75:22000->167.248.133.39:41226: read: connection reset by peer
2023-09-19 00:17:12 Listen (BEP/tcp): TLS handshake: tls: client offered only unsupported versions: [303 302 301]
2023-09-19 00:17:13 Listen (BEP/tcp): TLS handshake: tls: client offered only unsupported versions: [301 302 303]
2023-09-19 00:17:13 Listen (BEP/tcp): TLS handshake: tls: client offered only unsupported versions: [303 302 301]
2023-09-19 00:17:14 Listen (BEP/tcp): TLS handshake: tls: client offered only unsupported versions: [302 301]
2023-09-19 00:17:14 Listen (BEP/tcp): TLS handshake: tls: client requested unsupported application protocols ([hq h2c h2 spdy/3 spdy/2 spdy/1 http/1.1 http/1.0 http/0.9])
2023-09-19 00:17:14 Listen (BEP/tcp): TLS handshake: tls: client requested unsupported application protocols ([http/0.9 http/1.0 http/1.1 spdy/1 spdy/2 spdy/3 h2 h2c hq])
2023-09-19 00:17:14 Listen (BEP/tcp): TLS handshake: tls: no cipher suite supported by both client and server
2023-09-19 00:17:15 Listen (BEP/tcp): TLS handshake: tls: client requested unsupported application protocols ([hq h2c h2 spdy/3 spdy/2 spdy/1 http/1.1 http/1.0 http/0.9])
2023-09-19 09:00:15 Wrong credentials supplied during API authorization from 172.17.0.1:26880
2023-09-19 09:02:13 Pausing 3YCP6SQ-xxx
2023-09-19 09:02:15 Resuming 3YCP6SQ-xxx
2023-09-19 09:45:15 Enabled debug data for “dialer”
2023-09-19 09:45:16 Enabled debug data for “discover”
2023-09-19 09:45:18 Enabled debug data for “connections”
2023-09-19 09:45:19 dialing 3YCP6SQ-xxx quic://82.64.xxx:22000 error: dial: timeout: no recent network activity
2023-09-19 09:45:19 dialing 3YCP6SQ-xxx quic://192.168.xxx:22000 error: dial: timeout: no recent network activity
2023-09-19 09:45:19 failed to connect to 3YCP6SQ-xxx 40
2023-09-19 09:45:19 Next connection loop in 20s
2023-09-19 09:45:39 Connection loop
2023-09-19 09:45:39 negative cache entry for 3YCP6SQ-xxx at global@https://discovery-v6.syncthing.net/v2/ valid until 2023-09-19 09:13:36.32435095 +0200 CEST m=+61364.592302979 or 2023-09-19 10:12:36.32435102 +0200 CEST m=+64904.592303039
2023-09-19 09:45:39 cached discovery entry for 3YCP6SQ-xxx at global@https://discovery.syncthing.net/v2/
2023-09-19 09:45:39 cache: {[quic://192.168.xxx:22000 quic://82.64.xxx:22000 quic://82.64.xxx:22000 quic://[2a01:xxx]:22000 relay://212.5.154.218:443/?id=W42JIMZ-CAX2EUD-BRRVKZB-7OPY2EG-WTXRK65-VVKNURK-DF44QQH-6U2BYQ6 tcp://192.168.xxx:22000 tcp://82.64.xxx:22000 tcp://82.64.xxx:22000 tcp://[2a01:xxx]:22000 tcp://[2a01:xxx]:22000] {13923566662241067615 63108028801020 0x1a30900} true {0 0 } 0}
2023-09-19 09:45:39 negative cache entry for 3YCP6SQ-xxx at global@https://discovery-v4.syncthing.net/v2/ valid until 2023-09-19 09:13:36.324349597 +0200 CEST m=+61364.592301626 or 2023-09-19 10:12:36.324350188 +0200 CEST m=+64904.592302207
2023-09-19 09:45:39 lookup results for 3YCP6SQ-xxx
2023-09-19 09:45:39 addresses: [quic://192.168.xxx:22000 quic://82.64.xxx:22000 quic://[2a01:xxx]:22000 relay://212.5.154.218:443/?id=W42JIMZ-CAX2EUD-BRRVKZB-7OPY2EG-WTXRK65-VVKNURK-DF44QQH-6U2BYQ6 tcp://192.168.xxx:22000 tcp://82.64.xxx:22000 tcp://[2a01:xxx]:22000]
2023-09-19 09:45:39 Resolved device 3YCP6SQ-xxx addresses: [quic://192.168.xxx:22000 quic://82.64.xxx:22000 quic://[2a01:xxx]:22000 relay://212.5.154.218:443/?id=W42JIMZ-CAX2EUD-BRRVKZB-7OPY2EG-WTXRK65-VVKNURK-DF44QQH-6U2BYQ6 tcp://192.168.xxx:22000 tcp://82.64.xxx:22000 tcp://[2a01:xxx]:22000]
2023-09-19 09:45:39 Dialer for relay://212.5.154.218:443/?id=W42JIMZ-CAX2EUD-BRRVKZB-7OPY2EG-WTXRK65-VVKNURK-DF44QQH-6U2BYQ6: unsupported protocol: disabled by configuration
2023-09-19 09:45:39 dialing 3YCP6SQ-xxx tcp://[2a01:xxx]:22000 prio 30
2023-09-19 09:45:39 dialing 3YCP6SQ-xxx tcp://82.64.xxx:22000 prio 30
2023-09-19 09:45:39 Dialing reuse result tcp [2a01:xxx]:22000: dial tcp [::]:22000->[2a01:xxx]:22000: connect: cannot assign requested address
2023-09-19 09:45:39 dialing 3YCP6SQ-xxx tcp://192.168.xxx:22000 prio 30
2023-09-19 09:45:39 Dialing non-reuse result tcp [2a01:xxx]:22000: dial tcp [2a01:xxx]:22000: connect: cannot assign requested address
2023-09-19 09:45:39 dialing 3YCP6SQ-xxx tcp://[2a01:xxx]:22000 error: dial tcp [2a01:xxx]:22000: connect: cannot assign requested address
2023-09-19 09:45:39 Dialing reuse result tcp 82.64.xxx:22000: dial tcp [::]:22000->82.64.xxx:22000: connect: cannot assign requested address
2023-09-19 09:45:49 Dialing non-reuse result tcp 82.64.xxx:22000: dial tcp 82.64.xxx:22000: i/o timeout
2023-09-19 09:45:49 Dialing non-reuse result tcp 192.168.xxx:22000: dial tcp 192.168.xxx:22000: i/o timeout
2023-09-19 09:45:49 Dialing reuse result tcp 192.168.xxx:22000: dial tcp [::]:22000->192.168.xxx:22000: i/o timeout
2023-09-19 09:45:49 dialing 3YCP6SQ-xxx tcp://192.168.xxx:22000 error: dial tcp 192.168.xxx:22000: i/o timeout
2023-09-19 09:45:49 dialing 3YCP6SQ-xxx tcp://82.64.xxx:22000 error: dial tcp 82.64.xxx:22000: i/o timeout
2023-09-19 09:45:49 failed to connect to 3YCP6SQ-xxx 30
2023-09-19 09:45:49 dialing 3YCP6SQ-xxx quic://82.64.xxx:22000 prio 40
2023-09-19 09:45:49 dialing 3YCP6SQ-xxx quic://192.168.xxx:22000 prio 40
2023-09-19 09:45:49 dialing 3YCP6SQ-xxx quic://[2a01:xxx]:22000 prio 40
2023-09-19 09:45:49 dialing 3YCP6SQ-xxx quic://[2a01:xxx]:22000 error: dial: INTERNAL_ERROR (local): write udp [::]:22000->[2a01:xxx]:22000: sendmsg: cannot assign requested address
2023-09-19 09:45:54 dialing 3YCP6SQ-xxx quic://82.64.xxx:22000 error: dial: timeout: no recent network activity
2023-09-19 09:45:54 dialing 3YCP6SQ-xxx quic://192.168.xxx:22000 error: dial: timeout: no recent network activity
2023-09-19 09:45:54 failed to connect to 3YCP6SQ-xxx 40
2023-09-19 09:45:54 Next connection loop in 20s
2023-09-19 09:45:56 global@https://discovery-v6.syncthing.net/v2/ Announcement: {[quic://0.0.0.0:22000 quic://172.17.1.75:22000 tcp://0.0.0.0:22000 tcp://172.17.1.75:22000 tcp://0.0.0.0:0]}
2023-09-19 09:45:56 Dialing reuse result tcp discovery-v6.syncthing.net:443 : dial tcp [::]:22000->[2a03:b0c0:0:1010::bb:4001]:443: connect: cannot assign requested address
2023-09-19 09:45:56 Dialing non-reuse result tcp discovery-v6.syncthing.net:443 : dial tcp [2400:6180:100:d0::741:a001]:443: connect: cannot assign requested address
2023-09-19 09:45:56 global@https://discovery-v6.syncthing.net/v2/ announce POST: Post “https://discovery-v6.syncthing.net/v2/ ”: dial tcp [2400:6180:100:d0::741:a001]:443: connect: cannot assign requested address
bt90
(Bt90)
September 19, 2023, 7:57am
10
The 172.17.17.75 looks like an internal docker IP. Could you share the command you’re using or the compose file if that’s the case?
lilp69
(lilp)
September 19, 2023, 8:29am
11
I think it is address of my external node on ultraseedbox.
I just install package by they own services.
bt90
(Bt90)
September 19, 2023, 8:44am
12
Looks like you need to configure the address manually:
If that doesn’t work
lilp69
(lilp)
September 19, 2023, 12:02pm
13
Where I can configure it manually?
bt90
(Bt90)
September 19, 2023, 2:03pm
14
I’d try to follow the linked documentation of your provider. Check the Setting up Syncthing on Slot section.
lilp69
(lilp)
September 20, 2023, 7:25am
16
After uninstall and install Syncthing on my remote node. I can see my nodes. First sync is in progress.
Hope problem is solved.
Thanks for your time and your help.
system
(system)
Closed
October 20, 2023, 7:25am
17
