Different syncs from same folder
Hi I have a folder on my Pc with around 15 subfolders. I want to sync all of it to my wife’s PC. For reasons of both space and security I only want to sync a few of the subfolders to our mobiles So I set up a phone sync job which only synced the required folders using the Ignore Patterns. This worked fine Then I set up a PC sync to copy everything and it again only synced some folders - as far as I can tell the “ignore” list seems specific to the source folder and not the job. Is there a way round this?
That is unfortunately how it works. The workaround is to have the ignore patterns on the other side.
