Different sync locations for each device
the ability to choose which directory the file goes to on each pc, for example having an application data file on my windows pc go to an application data file on my linux pc (the apps have different locations that they store the data in but the stored files are exatly same)
You can configure each Folder on each Syncthing Device to use the Folder Path you want. The “Add Folder” button in the GUI brings you right to it.
