Did it not getting running
I want to use to Sync files between my Notebook and my Tablett. Looks all good, but the system did not sync, th 2 files at the test folder
Did someone please have a suggestion what can be missing? All standart settings from the program.
Thanks for help
Hello @Terra1961 and welcome here!
Please click on “2 elemente …” and screenshot what you see. :slight_smile:
Recreate a other folder helps for some time, the update it slowly. But than stuck again.
The list is now longer than two files. The top two files have characters which might very well not be legal in the tablet file system.
As for the rest, I don’t know. Maybe you just need some more patience? Are they still available on one or more of your devices? If they are unwanted, then you can create “dummy files” with such names and them delete them again.
Ps/ You might want to better self-review stuff you upload in the future. You have an “interesting” collection of files. :wink: /Ds
Yeah… so for the record, the reason things are syncing is usually easier seen on the receiving side.
If I create a Test folder with some Test TXT files it was copy directly. Only with the existing folders, it was the problem.
Getting connection, if I readd the existing folders. The scan than them, but no progress.
Looks like I get the fault. Looks more a problem with the space on the Micro SDHX Card.
