Devices out of sync but not relly
I have 2 devices syncing a folder “Maildir” between each other. Both on Arch Linux 64bit, syncthing 1.5.0
On both devices the folder is shown as up-to-date.
But in the devices list, both show 1: Out of Sync Items | 50 items, ~31.4 MiB 2: Out of Sync Items | 53 items, ~31.4 MiB
If I check what they are, seems they are waiting for each other:
dev1:
Path Size Mod. Time Mod. Device
.Archive/tmp 2020-05-15 10:12:30 dev2
dev2:
.Archive/tmp 2020-04-04 14:41:21 dev1
If I delete the folder .Archive/tmp, it does not help - it is correctly synchronized between the devices, but they stay out of sync.
Expected behavior:
The devices are not shown as out of sync.
Did you try searching existing threads for a solution?
Yes even some reddit discussions from Google search.
Presumably you tried delta resets and metadata recalculations?
syncthing -reset-deltas reduced the problem to 6 (9 on the other) items, but not fixed. How to do metadata recalculations?
Yes, it indeed helped!
