Devices disconnected when changing a folder settings
After editing a folder through Syncthing GUI, changing any setting and clicking “Save”, the devices that this folder is shared with become “Disconnected”. Then I have to wait the usual tens of seconds for the address to be discovered again and the devices to appear “Connected”.
Is that expected / a bug / something that could be improved? Should I create a GitHub issue to track this?
I use the default Global Discovery servers, if that is relevant.
Syncthing v1.3.1
It’s expected and it could be improved, but it’s tricky to get right in the current code base.
I don’t think there are massive tangible benefits of this tho.
I agree. The only benefit I see is the time saved when you’re performing the setup / playing with settings and would like to quickly see if the synchronization works correctly and as expected.
I figured out that - for my setup - the fastest way to get stuff back online again is to restart one of the instances after a config change. That’s a lot faster than waiting for the (re-)connect loop. But that likely depends on how long the inital scan takes on your machines.
