Device stuck at 99% but backup is successfully completed
On my syncthing server web gui, my folder says that it is “Up to Date”. Under Remote Devices, the device shows “Syncing (99%, 38MiB)”. I check the folder destination path, and all the files that should be there, are there. Why is it hung at 99%?
Check the Syncthing folder panel on the remote device. There’s likely an error message there.
