Device A
Device B
Sorry for the multiple posts.
I think I realized what is going on. Right now I just pressed the button “override changes” and files have been deletes. But unless I press that button, the deletions didn’t occurr. Why is that?
EDIT: in the cluster, there are only the two devices. These is a third device connected only to Device B, but regardless to the presence of this device the problem still exist.
So it’s not clear which of your devices is a master and where you are deleting files.
I’m sorry for the confusion. The master device is Device B, i make deletions on it but they’re not reproduced on device A.
Does A use some sort of network filesystem or perhaps FAT32 for storage?
It’s a truecrypt volume which I’m not sure how is formatted. Let me try to check (it could be NTFS ot ext4).
That’s probably the key here
Stupid truecrypt. I will try to figure out what filesystem is in use in that drive and post it here for other people with the same issue.
I really appreciate your help, thank you.
I don’t know for sure that it’s TrueCrypt: my comment was based off gut instinct.
I’m betting it’s a FAT filesystem anyway.
Also, search for truecrypt in the forms, there are a few options you need to tweak to make it work.
He isn’t synchronizing a TrueCrypt volume, he’s synchronizing into a mounted TrueCrypt volume (as I understand it). I haven’t seen that pop up on the forums yet.
You are right canton7.
Well, I have some news. I just realized that the encrypted drive is NTFS. It can’t be FAT32 because I am able to store files larger than 4GB. Do you think that this might be the issue? If yes, why everything works fine (that is, deletions executed on Device A are replicated on Device B) when I press the button “Override Changes”?
What happens, A adds files, B receives the file, somehow modifies it*, and tells A about the now new file. Because A is master it refuses it, hence deleting on A simply conflicts with new version on B, and B ends up keeping it.
Modifies it can mean:
That’s a very clear explanation and makes perfectly sense. It is very likely that it’s truecrypt’s fault. I will try first to create a truecrypt volume with ext4 filesystem, and see if it works. If it doesn’t I’ll try with other encryption softwares.
Thank you very much for your help.
