Hi everybody,
I am having troubles with my setup which is made by device A (a debian server where i backup my files) and device B (my windows 7 laptop, from where I do the backups.
The problem is that deletions made on my laptop, are not replicated on my server and the hard drive fills up after some time. Is it a problem of permissions?
I’m sorry for the off-topic question, but I can’t understand if -logfile option requires the full directory or the filename only. In case it is the filename only, where would the log file be placed?
If you’re using systemd, don’t use logfile but instead view the log with sudo journalctl -r -u <user>@syncthing.service, e.g. sudo journalctl -r -u syncthing@syncthing.service.
Let’s take the folder desktop, for example. I just created two files: srvr.png and pc.png on device B. They have been transfered to device A (I checked, they were on device A). Afterwards I deleted them on device B, but even after 10 minutes and rescanning the desktop folder, they still were on the device A.
This happened in the last 15-20 minutes. Here is the log of that time frame.
Feb 08 13:41:28 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:28 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Feb 08 13:41:28 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:28 INFO: Puller (folder "Desktop", file "pc.png"): pull: peers who had this file went away, or the file has changed while syncing
Feb 08 13:41:27 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:27 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Feb 08 13:41:27 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:27 INFO: Puller (folder "Desktop", file "srvr.png"): pull: peers who had this file went away, or the file has changed while synci
Feb 08 13:41:20 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:20 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Feb 08 13:41:20 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:20 INFO: Puller (folder "Desktop", file "srvr.png"): pull: peers who had this file went away, or the file has changed while synci
Feb 08 13:41:19 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:19 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Feb 08 13:41:19 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:19 INFO: Puller (folder "Desktop", file "pc.png"): pull: peers who had this file went away, or the file has changed while syncing
Feb 08 13:41:10 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:10 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Feb 08 13:41:10 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:10 INFO: Puller (folder "Desktop", file "srvr.png"): pull: peers who had this file went away, or the file has changed while synci
Feb 08 13:41:09 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:09 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Feb 08 13:41:09 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:41:09 INFO: Puller (folder "Desktop", file "pc.png"): pull: peers who had this file went away, or the file has changed while syncing
Feb 08 13:38:40 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:40 INFO: Completed initial scan (rw) of folder Pictures
Feb 08 13:38:39 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:39 INFO: Completed initial scan (rw) of folder Documents
Feb 08 13:38:39 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:39 INFO: Completed initial scan (rw) of folder Musica
Feb 08 13:38:38 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:38 INFO: Device UXTKEHQ-AMQKKO3-QYJ7PN5-7FDZ6QB-FRWVIPJ-7YHRGK4-LHVQGVK-5CMWYQK client is "syncthing v0.12.17" named "GC01PC"
Feb 08 13:38:38 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:38 INFO: Established secure connection to UXTKEHQ-AMQKKO3-QYJ7PN5-7FDZ6QB-FRWVIPJ-7YHRGK4-LHVQGVK-5CMWYQK at 192.168.10.100:22000
Feb 08 13:38:37 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:37 INFO: Completed initial scan (rw) of folder Thunderbird
Feb 08 13:38:37 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:37 INFO: Completed initial scan (rw) of folder Desktop
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: Completed initial scan (rw) of folder Firefox
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: Completed initial scan (rw) of folder OwnCloud
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: GUI URL is https://127.0.0.1:8384/
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: API listening on [::]:8384
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: Completed initial scan (rw) of folder Blackberry
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: Device UXTKEHQ-AMQKKO3-QYJ7PN5-7FDZ6QB-FRWVIPJ-7YHRGK4-LHVQGVK-5CMWYQK is "GC01PC" at [dynamic]
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 INFO: Device M5B2SHV-AWJQRV6-5CMIYHF-SNS34CL-CEXCHSO-2TCKFC7-FOTTXF7-KLXBWAJ is "GC01SRVR" at [dynamic]
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 OK: Ready to synchronize Thunderbird (read-write)
Feb 08 13:38:34 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:34 OK: Ready to synchronize Pictures (read-write)
Feb 08 13:38:33 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:33 OK: Ready to synchronize OwnCloud (read-write)
Feb 08 13:38:33 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:33 OK: Ready to synchronize Musica (read-write)
Feb 08 13:38:33 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:33 OK: Ready to synchronize Firefox (read-write)
Feb 08 13:38:32 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:32 OK: Ready to synchronize Documents (read-write)
Feb 08 13:38:32 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:32 OK: Ready to synchronize Desktop (read-write)
Feb 08 13:38:31 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:31 OK: Ready to synchronize Blackberry (read-write)
Feb 08 13:38:14 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:14 INFO: Single thread hash performance is ~178 MB/s
Feb 08 13:38:14 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:14 INFO: My ID: M5B2SHV-AWJQRV6-5CMIYHF-SNS34CL-CEXCHSO-2TCKFC7-FOTTXF7-KLXBWAJ
Feb 08 13:38:14 GC01SRVR syncthing[26453]: [M5B2S] 2016/02/08 13:38:14 INFO: syncthing v0.12.15 "Beryllium Bedbug" (go1.5.3 linux-amd64) unknown-user@build2.syncthing.net 2016-01-17 09:57:20 UTC
Feb 08 13:38:14 GC01SRVR syncthing[20569]: [M5B2S] 2016/02/08 13:38:14 OK: Exiting
Feb 08 13:38:14 GC01SRVR syncthing[20569]: [M5B2S] 2016/02/08 13:38:14 INFO: Restarting
