just migrating from BT Sync to Syncthing.
Is that possible to update only big (200-200 GB) single files without syncing the whole file again?
thanks.
thanks.
I’m not 100% sure if i understood this right how it works but it should be like this:
Alex is spot on. If your append in the middle/prepend was a multiple of 128kb, you’re still good.
Thanks, that was my question exactly!
It is great it works like this, so I can still sync/update only the difference in huge files.
