For a few weeks I’ve had this problem with one folder being stuck in sync between multiple devices. The folder itself has been deleted and doesn’t exist anywhere anymore.
Resetting deltas has no effect. Do you have any idea what may be going on here?
The folder itself doesn’t exist on any device anymore though. I think that it originated from 6S74IT, and then got synced to D4DZUG, where I then deleted it. All three also use the same ignore patterns.
Same ignore pattern shouldn’t be possible, given one device shows the item as not ignored. Anyhow given this doesn’t exist any more, not much to investigate here.
but those are long gone with the parent folder too.
How to cleanly fix this kind of a situation though? Is removing and re-adding the folder and/or resetting the database the only way to get rid of the error?
The situation is essentially that the rest info is wrong . In reality, the folder doesn’t exist anywhere, including 6S74IT.
I have just temporarily unshared the folder from 6S74IT, and now everything reports as “Up to Date”. I wonder what will happen when I relink it again later (as the device is offline right now).
