Hello,
I’ve been using Syncthing for my personal documents and files for a while now and it works perfectly, now I was thinking about using it to sync two servers that run a kind of a load balancing / redundancy situation used to store maildirs.
From time to time I’ve seen ext4 going bad, be it due to a disk dying or a power issue that made the filesystem go read-only, unmount itself or show as an empty directory.
How does Syncthing handle this types of failures? What will happen if for instance all the files in one of the servers disappear? Will it delete all files on the other server?
What are your general recommendations for a use case like this?
Thank you.
