I just installed Syncthing in 3 systems, a Rasbperry Pi 2 with Raspbian, a Windows 10 Profesional and a Windows 10 Home.
All three systems are in the same LAN and all connected through Ethernet.
It is a 7GB share and the Pi and the Windows Pro synchronised straight away, but after keeping the Windows Home running for three days it is still at 7% Global state: 58460 ítems, ~7.04 GiB Local state: 9111 ítems, ~661 MiB
Any suggestions about how to trouble shoot it?
Thanks in advance.
JD Evora
[UOL7Z] 23:08:19 INFO: syncthing v0.14.7 “Dysprosium Dragonfly” (go1.7.1 windows-amd64) jenkins@build.syncthing.net 2016-09-18 19:02:42 UTC [UOL7Z] 23:08:19 INFO: My ID: UOL7XXX [UOL7Z] 23:08:20 INFO: Single thread hash performance is ~78 MB/s [UOL7Z] 23:08:31 INFO: Ready to synchronize dlaiz-3srsf (readwrite) [UOL7Z] 23:08:31 INFO: Ready to synchronize f7ulc-qcmaq (readwrite) [UOL7Z] 23:09:13 INFO: Ready to synchronize fm9jx-v5h4r (readwrite) [UOL7Z] 23:09:13 INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY [UOL7Z] 23:09:13 INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3 [UOL7Z] 23:09:13 INFO: Using discovery server https://discovery-v4-4.syncthing.net/v2/?id=LYXKCHX [UOL7Z] 23:09:13 INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY [UOL7Z] 23:09:13 INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3 [UOL7Z] 23:09:13 INFO: Using discovery server https://discovery-v6-4.syncthing.net/v2/?id=LYXKCHX [UOL7Z] 23:09:13 INFO: TCP listener ([::]:22000) starting [UOL7Z] 23:09:13 INFO: Device MMUWXXX is “cryptoPi” at [dynamic] [UOL7Z] 23:09:13 INFO: Device TOQKXXX is “DellVisin” at [dynamic] [UOL7Z] 23:09:13 INFO: Device UOL7XXX is “plateadin” at [dynamic] [UOL7Z] 23:09:14 INFO: Completed initial scan (rw) of folder f7ulc-qcmaq [UOL7Z] 23:09:14 INFO: GUI and API listening on 127.0.0.1:8384 [UOL7Z] 23:09:14 INFO: Access the GUI via the following URL: http://localhost:8384/ [UOL7Z] 23:09:16 INFO: Invalid IGD response: invalid device UUID upnp-InternetGatewayDevice-1_0-58238cc414ce (continuing anyway) [UOL7Z] 23:09:20 INFO: Established secure connection to MMUWXXX at 192.168.22.18:22000-85.155.227.237:45191 (TCP (Server)) [UOL7Z] 23:09:20 INFO: Device MMUWXXX client is “syncthing v0.14.7” named “raspberrypi” [UOL7Z] 23:09:27 INFO: New NAT port mapping: external TCP address 85.155.227.237:27414 to local address 0.0.0.0:22000. [UOL7Z] 23:09:27 INFO: Detected 1 NAT device [UOL7Z] 23:09:36 INFO: Joined relay relay://195.154.97.57:22067 [UOL7Z] 23:09:51 INFO: Established secure connection to TOQKXXX at 192.168.22.18:22000-192.168.22.14:59159 (TCP (Server)) [UOL7Z] 23:09:51 INFO: Device TOQKXXX client is “syncthing v0.14.7” named “DellVisin” [UOL7Z] 23:09:51 INFO: Connection to TOQKXXX closed: reading length: read tcp 192.168.22.18:22000->192.168.22.14:59159: wsarecv: Se ha anulado una conexión establecida por el software en su equipo host… [UOL7Z] 23:09:56 INFO: Device MMUWXXX folder “fm9jx-v5h4r” is delta index compatible (mlv=73210) [UOL7Z] 23:09:56 INFO: Device MMUWXXX folder “dlaiz-3srsf” is delta index compatible (mlv=14466) [UOL7Z] 23:10:22 INFO: Failed to exchange Hello messages with MMUWXXX ([fe80::ba27:ebff:fe9b:55d9%Ethernet]:22000): write tcp [fe80::3403:5f62:d02b:7484%Ethernet]:58441->[fe80::ba27:ebff:fe9b:55d9%Ethernet]:22000: wsasend: Se ha forzado la interrupción de una conexión existente por el host remoto. [UOL7Z] 23:10:32 INFO: Established secure connection to TOQKXXX at 192.168.22.18:58517-192.168.22.14:22000 (TCP (Client)) [UOL7Z] 23:10:32 INFO: Device TOQKXXX client is “syncthing v0.14.7” named “DellVisin” [UOL7Z] 23:11:20 INFO: Connected to already connected device (TOQKXXX) [UOL7Z] 23:11:21 INFO: Device TOQKXXX folder “dlaiz-3srsf” is delta index compatible (mlv=14267) [UOL7Z] 23:11:21 INFO: Device TOQKXXX folder “fm9jx-v5h4r” is delta index compatible (mlv=72030) [UOL7Z] 23:12:04 INFO: Completed initial scan (rw) of folder dlaiz-3srsf [UOL7Z] 23:12:11 INFO: Connected to already connected device (TOQKXXX) [UOL7Z] 23:13:00 INFO: Completed initial scan (rw) of folder fm9jx-v5h4r [UOL7Z] 23:13:26 INFO: Connection to TOQKXXX closed: writing message: write tcp 192.168.22.18:58517->192.168.22.14:22000: wsasend: Se ha forzado la interrupción de una conexión existente por el host remoto. [UOL7Z] 23:13:26 INFO: Established secure connection to TOQKXXX at 192.168.22.18:22000-192.168.22.14:59239 (TCP (Server)) [UOL7Z] 23:13:26 INFO: Device TOQKXXX client is “syncthing v0.14.7” named “DellVisin” [UOL7Z] 23:13:26 INFO: Device TOQKXXX folder “dlaiz-3srsf” is delta index compatible (mlv=14267) [UOL7Z] 23:13:26 INFO: Device TOQKXXX folder “fm9jx-v5h4r” is delta index compatible (mlv=72030)
