Custom device address is not propagated to Discovery servers
In the advanced settings in the device section I have entered the following: “tcp://xxxx.no-ip.net, dynamic”: one is a dynamic DNS that resolves to my router’s IP address and the other the dynamic setting for global/local discovery.
I can connect to this Syncthing instance successfully only if I manually enter “tcp://xxxx.no-ip.net” on my phone or some other instance… however I didn’t expect to have to do this. I would assume that with “global discovery” enabled on the device and these settings, “tcp://xxxx.no-ip.net” would be advertised to other clients when they have the ID. However this doesn’t seem to happen. Any ideas what’s going wrong?
Global discovery should work yes if I understand your setup correctly. It doesn’t know or care whether you have a DNS name somewhere that points to the device, most people don’t and it works for them. So I’m not sure what goes wrong for you.
