I built my own syncthing binary from the github code, but as soon as I run it it downloads (autoupdates) a new version from god-knows-where and starts to run that instead.
This ‘feature’ seems very sketchy to me. I know you’re probably just trying to ensure everybody runs the latest and greatest version, but I compile my own version for a reason and don’t want to run some unknown binary from the internet.
After readling all the big words about openness and privacy on your site/forums I would have expected you to think this through better.
Ok, good. Can I propose to set the default to 0 when building from source. If you custom build software you nearly always intend to run your just-compiled version I’d think.
Yeah, I’ve occasionally been bitten by this one myself, although usually master is ahead of the released version so it doesn’t happen that often. Fixed now anyway; auto upgrade is disabled in non-release builds, i.e. ones where the version isn’t a clean vX.Y.Z(-beta…).
If you want to do release builds and avoid the upgrading stuff, simply building it without support for upgrade (go run build.go -no-upgrade) is cleanest.
