Current build of DMG for OSX
Would it be possible to get a current Syncthing Mac OS installer DMG? The most current one seems to be v2.0.3:
I usually install via HomeBrew, but I have a couple of machines that have been upgraded from previous versions of MacOS and have, from what I can tell, widely-reported issues with the application firewall and never prompt to allow network access. I’ve been around and around a few times trying to fix this, but the easiest solution (and the only one that works, to date) was to install Syncthing from the DMG. Being able to keep up-to-date on the many changes/fixes since 2.0.3 would be awesome.
I’m looking specifically for the Intel version, not Apple Silicon.
Thanks for all the work by the devs and the rest of the community.
Regards
I’m not particularly involved with that release, but I know that apart from the GUI functionality it simply wraps the binary Syncthing release that you can download on Syncthing | Downloads and, I think, enables auto upgrades. Which is to say, it shouldn’t make much of a difference if it’s v2.0.3 or v2.0.11, and if it does you can just replace the Syncthing binary after installation…
Thanks! It worked for me :slight_smile: .
