--------- beginning of main
--------- beginning of crash
06-04 19:30:13.503 W/SyncthingNativeCode(15302): error: "/data/app/com.nutomic.syncthingandroid-TuGbHKYN-pIaA-u-LolTBQ==/lib/arm64/libsyncthing.so": executable's TLS segment is underaligned: alignment is 8, needs to be at least 64 for ARM64 Bionic
06-04 19:30:01.753 E/yncthingandroi(15302): Not starting debugger since process cannot load the jdwp agent.
06-04 19:30:01.771 I/yncthingandroi(15302): The ClassLoaderContext is a special shared library.
06-04 19:30:02.106 I/Adreno (15302): QUALCOMM build : b9e1f90, I42c2d2af0a
06-04 19:30:02.106 I/Adreno (15302): Build Date : 03/22/19
06-04 19:30:02.106 I/Adreno (15302): OpenGL ES Shader Compiler Version: EV031.26.04.00
06-04 19:30:02.106 I/Adreno (15302): Local Branch : gfx-adreno.lnx.1.0
06-04 19:30:02.106 I/Adreno (15302): Remote Branch : quic/gfx-adreno.lnx.1.0
06-04 19:30:02.106 I/Adreno (15302): Remote Branch : NONE
06-04 19:30:02.106 I/Adreno (15302): Reconstruct Branch : NOTHING
06-04 19:30:02.106 I/Adreno (15302): Build Config : S P 8.0.5 AArch64
06-04 19:30:02.119 I/Adreno (15302): PFP: 0x016ee183, ME: 0x00000000
06-04 19:30:02.151 W/Gralloc3(15302): mapper 3.x is not supported
06-04 19:30:02.156 W/RenderThread(15302): type=1400 audit(0.0:1523): avc: denied { read } for name="u:object_r:vendor_default_prop:s0" dev="tmpfs" ino=24808 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:vendor_default_prop:s0 tclass=file permissive=0
06-04 19:30:02.158 E/libc (15302): Access denied finding property "vendor.gralloc.disable_ahardware_buffer"
06-04 19:30:06.127 I/FirstStartActivity(15302): User granted WRITE_EXTERNAL_STORAGE permission.
06-04 19:30:10.877 I/FirstStartActivity(15302): User granted ACCESS_COARSE_LOCATION permission.
06-04 19:30:13.378 W/ActivityThread(15302): handleWindowVisibility: no activity for token android.os.BinderProxy@ec0f973
06-04 19:30:13.458 I/SyncthingService(15302): shouldRun decision changed to true according to configured run conditions.
06-04 19:30:13.458 I/SyncthingService(15302): Shutting down background service
06-04 19:30:13.459 I/ConfigXml(15302): App started for the first time. Generating keys and config.
06-04 19:30:13.459 W/Notification(15302): Use of stream types is deprecated for operations other than volume control
06-04 19:30:13.459 W/Notification(15302): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
06-04 19:30:13.493 W/chmod (15350): type=1400 audit(0.0:1525): avc: denied { setattr } for name="libsyncthing.so" dev="dm-6" ino=780110 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:apk_data_file:s0 tclass=file permissive=0
06-04 19:30:13.495 I/SyncthingRunnable(15302): increaseInotifyWatches: Root is not available. Cannot increase inotify limit.
06-04 19:30:13.500 I/SyncthingRunnableIoNice(15302): Root is not available. Cannot nice syncthing.
06-04 19:30:13.503 F/libc (15353): error: "/data/app/com.nutomic.syncthingandroid-TuGbHKYN-pIaA-u-LolTBQ==/lib/arm64/libsyncthing.so": executable's TLS segment is underaligned: alignment is 8, needs to be at least 64 for ARM64 Bionic
06-04 19:30:13.503 F/libc (15353): Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 15353 (libsyncthing.so), pid 15353 (libsyncthing.so)
06-04 19:30:13.517 W/Notification(15302): Use of stream types is deprecated for operations other than volume control
06-04 19:30:13.517 W/Notification(15302): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
06-04 19:30:13.519 W/Notification(15302): Use of stream types is deprecated for operations other than volume control
06-04 19:30:13.519 W/Notification(15302): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
06-04 19:30:13.521 W/Notification(15302): Use of stream types is deprecated for operations other than volume control
06-04 19:30:13.521 W/Notification(15302): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
06-04 19:30:13.523 I/crash_dump64(15362): obtaining output fd from tombstoned, type: kDebuggerdTombstone
06-04 19:30:13.526 I/crash_dump64(15362): performing dump of process 15353 (target tid = 15353)
06-04 19:30:13.527 F/DEBUG (15362): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
06-04 19:30:13.527 F/DEBUG (15362): Build fingerprint: 'google/crosshatch/crosshatch:10/QPP3.190404.015/5505587:user/release-keys'
06-04 19:30:13.527 F/DEBUG (15362): Revision: 'MP1.0'
06-04 19:30:13.527 F/DEBUG (15362): ABI: 'arm64'
06-04 19:30:13.535 F/DEBUG (15362): Timestamp: 2019-06-04 19:30:13-0400
06-04 19:30:13.535 F/DEBUG (15362): pid: 15353, tid: 15353, name: libsyncthing.so >>> /data/app/com.nutomic.syncthingandroid-TuGbHKYN-pIaA-u-LolTBQ==/lib/arm64/libsyncthing.so <<<
06-04 19:30:13.535 F/DEBUG (15362): signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
06-04 19:30:13.535 F/DEBUG (15362): Abort message: 'error: "/data/app/com.nutomic.syncthingandroid-TuGbHKYN-pIaA-u-LolTBQ==/lib/arm64/libsyncthing.so": executable's TLS segment is underaligned: alignment is 8, needs to be at least 64 for ARM64 Bionic'
06-04 19:30:13.535 F/DEBUG (15362): x0 0000000000000000 x1 0000000000003bf9 x2 0000000000000006 x3 0000007ffb10ee50
06-04 19:30:13.535 F/DEBUG (15362): x4 0000000000000000 x5 0000000000000000 x6 0000000000000000 x7 0000000000000038
06-04 19:30:13.535 F/DEBUG (15362): x8 00000000000000f0 x9 e721fa6011a29480 x10 0000000000000001 x11 0000000000000000
06-04 19:30:13.535 F/DEBUG (15362): x12 fffffff0ffffffdf x13 0000000000000018 x14 000000030015ce12 x15 001dcf6cd5603dc8
06-04 19:30:13.535 F/DEBUG (15362): x16 000000000004cd20 x17 9ae16a3b2f90404f x18 0000007df1f78000 x19 0000000000003bf9
06-04 19:30:13.535 F/DEBUG (15362): x20 0000000000003bf9 x21 00000000ffffffff x22 0000007df2b2f5b0 x23 0000007df1950680
06-04 19:30:13.535 F/DEBUG (15362): x24 0000007df18eb010 x25 0000007df2b2f000 x26 0000007df2b2f5a0 x27 0000007df2b2f9a0
06-04 19:30:13.535 F/DEBUG (15362): x28 0000007df2b2f000 x29 0000007ffb10eef0
06-04 19:30:13.535 F/DEBUG (15362): sp 0000007ffb10ee30 lr 0000007df2afa6a8 pc 0000007df2afa6d4
06-04 19:30:13.539 F/DEBUG (15362):
06-04 19:30:13.539 F/DEBUG (15362): backtrace:
06-04 19:30:13.539 F/DEBUG (15362): #00 pc 00000000000e16d4 /apex/com.android.runtime/bin/linker64 (__dl_abort+160) (BuildId: 88632f32fe4312982316f8dae343e7)
06-04 19:30:13.539 F/DEBUG (15362): #01 pc 0000000000102110 /apex/com.android.runtime/bin/linker64 (__dl__ZN15StaticTlsLayout27reserve_exe_segment_and_tcbEPK10TlsSegmentPKc+268) (BuildId: 88632f32fe4312982316f8dae343e7)
06-04 19:30:13.539 F/DEBUG (15362): #02 pc 0000000000051acc /apex/com.android.runtime/bin/linker64 (__dl__Z27linker_setup_exe_static_tlsPKc+68) (BuildId: 88632f32fe4312982316f8dae343e7)
06-04 19:30:13.539 F/DEBUG (15362): #03 pc 000000000004caf0 /apex/com.android.runtime/bin/linker64 (__dl__ZL29__linker_init_post_relocationR19KernelArgumentBlockR6soinfo+3088) (BuildId: 88632f32fe4312982316f8dae343e7)
06-04 19:30:13.539 F/DEBUG (15362): #04 pc 000000000004be84 /apex/com.android.runtime/bin/linker64 (__dl___linker_init+396) (BuildId: 88632f32fe4312982316f8dae343e7)
06-04 19:30:13.539 F/DEBUG (15362): #05 pc 0000000000053104 /apex/com.android.runtime/bin/linker64 (__dl__start+4) (BuildId: 88632f32fe4312982316f8dae343e7)
06-04 19:30:13.547 I/SyncthingRunnable(15302): Syncthing exited with code 134
06-04 19:30:13.547 W/SyncthingRunnable(15302): Syncthing has crashed (exit code 134)
06-04 19:30:13.549 E/SyncthingUtil(15302): Root is not available. Cannot fix permissions.
06-04 19:30:13.550 W/Notification(15302): Use of stream types is deprecated for operations other than volume control
06-04 19:30:13.550 W/Notification(15302): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
06-04 19:30:13.566 W/Notification(15302): Use of stream types is deprecated for operations other than volume control
06-04 19:30:13.566 W/Notification(15302): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
06-04 19:30:13.690 E/WindowManager(15302):
06-04 19:30:13.690 E/WindowManager(15302): android.view.WindowLeaked: Activity com.nutomic.syncthingandroid.activities.MainActivity has leaked window DecorView@16cc7d4[MainActivity] that was originally added here
06-04 19:30:13.690 E/WindowManager(15302): at android.view.ViewRootImpl.<init>(ViewRootImpl.java:627)
06-04 19:30:13.690 E/WindowManager(15302): at android.view.WindowManagerGlobal.addView(WindowManagerGlobal.java:377)
06-04 19:30:13.690 E/WindowManager(15302): at android.view.WindowManagerImpl.addView(WindowManagerImpl.java:95)
06-04 19:30:13.690 E/WindowManager(15302): at android.app.Dialog.show(Dialog.java:342)
06-04 19:30:13.690 E/WindowManager(15302): at android.app.AlertDialog$Builder.show(AlertDialog.java:1131)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.StateDialogActivity.showLoadingDialog(StateDialogActivity.java:170)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.StateDialogActivity.onServiceStateChange(StateDialogActivity.java:83)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.StateDialogActivity.bridge$lambda$0$StateDialogActivity(Unknown Source:0)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.StateDialogActivity$$Lambda$7.onServiceStateChange(Unknown Source:2)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.service.SyncthingService.registerOnServiceStateChangeListener(SyncthingService.java:561)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.StateDialogActivity.lambda$onCreate$0$StateDialogActivity(StateDialogActivity.java:41)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.StateDialogActivity$$Lambda$0.onServiceConnected(Unknown Source:2)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.SyncthingActivity$$Lambda$0.accept(Unknown Source:2)
06-04 19:30:13.690 E/WindowManager(15302): at com.annimon.stream.Stream.forEach(Stream.java:1479)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.SyncthingActivity.onServiceConnected(SyncthingActivity.java:74)
06-04 19:30:13.690 E/WindowManager(15302): at com.nutomic.syncthingandroid.activities.MainActivity.onServiceConnected(MainActivity.java:300)
06-04 19:30:13.690 E/WindowManager(15302): at android.app.LoadedApk$ServiceDispatcher.doConnected(LoadedApk.java:1957)
06-04 19:30:13.690 E/WindowManager(15302): at android.app.LoadedApk$ServiceDispatcher$RunConnection.run(LoadedApk.java:1989)
06-04 19:30:13.690 E/WindowManager(15302): at android.os.Handler.handleCallback(Handler.java:883)
06-04 19:30:13.690 E/WindowManager(15302): at android.os.Handler.dispatchMessage(Handler.java:100)
06-04 19:30:13.690 E/WindowManager(15302): at android.os.Looper.loop(Looper.java:214)
06-04 19:30:13.690 E/WindowManager(15302): at android.app.ActivityThread.main(ActivityThread.java:7116)
06-04 19:30:13.690 E/WindowManager(15302): at java.lang.reflect.Method.invoke(Native Method)
06-04 19:30:13.690 E/WindowManager(15302): at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
06-04 19:30:13.690 E/WindowManager(15302): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:925)
06-04 19:30:17.272 W/ActivityThread(15302): handleWindowVisibility: no activity for token android.os.BinderProxy@58099b1
06-04 19:30:25.437 W/androidtc(15302): TextClassifier called on main thread
06-04 19:30:27.622 W/androidtc(15302): TextClassifier called on main thread
06-04 19:30:28.707 W/androidtc(15302): TextClassifier called on main thread
06-04 19:30:30.313 W/androidtc(15302): TextClassifier called on main thread
Thanks…
