Couldn't add port mapping for 192.168.178.xx ... Error: ConflictInMappingEntry (718)
In my network exist 2 Syncthing installations: One installation on a Windows 10 PC, an other on a raspberry pi.
I have some error messages in my Syncthing console (Windows 10):
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 48014 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 31800 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 42214 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 17128 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 60811 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 25856 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 47693 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 42945 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 40481 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 8374 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 59951 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 37804 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 34739 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 35704 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 27988 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 63004 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 15314 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:40 INFO: Couldn't add port mapping for 192.168.178.77 (external port 14604 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:41 INFO: Couldn't add port mapping for 192.168.178.77 (external port 15821 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
[XXXXX] 2024/02/08 18:24:41 INFO: Couldn't add port mapping for 192.168.178.77 (external port 21416 -> internal port 22000/TCP): UPnP Error: ConflictInMappingEntry (718)
These are my settings in the AVM Fritz!Box:
Are they correct?
What can I do to get rid of the error messages?
Edit: If I shutdown syncthing on the raspberry pi, the error messages stay nonetheless.
That’s a bug in AVM’s UPnP implementation. It is supposedly fixed in Fritz!OS 7.80 (available for some models).
For now I would just ignore it, until your router receives a patch.
Also, if you enable “selbstständige Portfreigaben erlauben” as you have, there is no need to create manual port forwards. They will just clash with the automatically managed ones.
Thank you very much. (My fritz!box 7490 is on 7.57.)
