New user, setting up a sync between Macbook and ubuntu headless server.
using apt-get to install, then run syncthing, I get a lot of ‘Could not add port mapping’. I am not able to see the gui from the MacBook.
for ubuntu I followed: apt.syncthing.net
I changed firewall rules: /t/ubuntu-server-ufw-configuration-help/21897/6
I followed
/t/syncthing-server-disconects-when-the-ssh-session-is-closed/11168
to check service
chris@nas04:~$ systemctl --user status syncthing.service
○ syncthing.service - Syncthing - Open Source Continuous File Synchronization
Loaded: loaded (/usr/lib/systemd/user/syncthing.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:syncthing(1)
chris@nas04:~$
I tried changing the config file as in
docs /users/faq.html#how-do-i-access-the-web-gui-from-another-computer
but there is no .config/syncthing/config.xml file. as you might find in
dig ocean dot com /community/tutorials/how-to-install-and-configure-syncthing-to-synchronize-directories-on-ubuntu-14-04
But all of that is irrelevant because this
forum st /t/couldnt-add-port-mapping-for-192-168-178-xx-error-conflictinmappingentry-718/21605
tells me if my fritzbox 7530 thinks it is uptodate on version 7.57, then I cannot get version 7.8, where the issue is resolved.
Not sure where I am going or what is happening. Would someone take a moment to direct me?
The port mapping error is a UPnP issue with your router and isn’t related to remote access to Syncthing’s web UI.
According to the systemctl output, Syncthing wasn’t running and the service wasn’t enabled. If you want Syncthing to auto-start whenever the server boots up:
loginctl enable-linger chris
systemctl --user enable syncthing
Reboot the server to verify that it’s working.
(Note that in step 2, the command is most often formally written as systemctl --user enable syncthing.service. If not specified, a “service” unit type is assumed.)
From your Mac, open a terminal and issue the following command (substituting your Ubuntu server’s IP address, or hostname, in place of x.x.x.x):
ssh -L 48384:127.0.0.1:8384 chris@x.x.x.x
After successfully logging onto your Ubuntu server, open a web browser on your Mac and go to http://127.0.0.1:48384/ to access Syncthing’s web UI on the server.
