If you were using the installed version of SyncTrayzor, then Syncthing’s config/index are kept in their default location: %LOCALAPPDATA%\Syncthing.
I’m not sure where Syncthing-GTK keeps Syncthing’s config, but a glance at the source suggests it’s the same location. So just installing Syncthing-GTK may well work
EDIT: Ah, no, or it might be %LOCALAPPDATA%\syncthing-gtk\syncthing
copy SyncTrayzor index database, if applicable, to avoid SyncthingGTK having to rescan all the shares.
There’s no such thing: Syncthing has an index, but it’s nothing to do with SyncTrayzor. It will be stored in %LOCALAPPDATA%\Syncthing.
I think I’ve sorted it out, by copying only the config.xml file from the source to the destination. Don’t know how indexing will go, but I’ll wait and see.
Yeah, but I still haven’t found out where Syncthing-GTK stores its database. I’m running SyncTrayzor Portable, so I just have to move the “data” folder when upgrading. I thought it was generated by SyncTrayzor.
Sure the data folder is generated by SyncTrayzor, but the syncthing folder it contains is generated by Syncthing
And again with Syncthing-GTK: I’m pretty sure it just lets Syncthing have free reign over a directory (which I think is %LOCALAPPDATA%\syncthing), so you should just be able to copy data\syncthing to %LOCALAPPDATA%\syncthing.
EDIT: You say you copied config.xml. The database should be in the same folder as config.xml, in both Syncthing-GTK and SyncTrayzor.
Genius !
I admit I haven’t paid attention to it, so yes, everything was in the directory.
I’ll copy it now to prevent Syncthing-GTK rebuilding all the index from scratch.
Thank you !
By the way, what made me try Syncthing-GTK is that Syncthing et SyncTrayzor processes have lately being hogging all the disk (usage @ 99-100% permanently), almost freezing the computer. I’ve even had two or three BSODs and force-restarts over the last weekend.
I still can’t tell if it’s ST itself or the wrapper. Nothing has changed in my config, I think it occurred after the Syncthing 0.11.13 upgrade.
Do you have any idea ? Is it even the appropriate place to discuss this, or should I open another thread ?
Impressive! You should be able to tell whether it’s Syncthing or SyncTrayzor by seeing whether the Syncthing or SyncTrayzor process is the one hogging the disk
You could also run syncthing on its own (no wrapper) and see if that hogs your disk.
That’s the point : both hog the disk, either alternatively, or simultaneously (in this last case, when I’m not present to stop both processes, I’m quite sure to get a forced reboot + the loss of current work ).
I repeat, it didn’t occurred so hard before (excepted for the initial building of the index).
I’ll keep doing various tests and try to determine what is wrong in my config.
Note that ‘Scanning’ means ‘looking for changes’. It has nothing to do with whether it’s synced - if it didn’t scan, it wouldn’t know if anything changed that it has to sync (note that SyncTrayzor mitigates this to an extent by looking for changes as they occur, so you can set a longer polling interval in Syncthing and have it scan less often).
