I was struggling with an erratic connection to my newly setup syncthing server running on a VM behind an nginx reverse proxy. After a while I figured out that this is related to my SSH connection with the server. All the following work when I am SSHed into the VM, and fail when I am out:
- Syncing to my local device (shows VM as “Disconnected”, if I hardcode its static IP I get a “connection refused”)
- Connection to the webinterface via nginx (502 Bad Gateway)
- Connection to the webinterface via http://IP:8384 (“Firefox can’t establish a connection”)
Evidently this has nothing to do with nginx itself, that is only a symptom, but for completeness I will add that I followed the guide on Reverse Proxy Setup — Syncthing v1 documentation and have the following config file for nginx:
server {
listen 80;
listen [::]:80;
server_name DOMAIN;
# location / { return 301 https://$host$request_uri; }
#server {
# listen 443 ssl http2;
# listen [::]:443 ssl http2;
# server_name DOMAIN;
# ssl_certificate /etc/letsencrypt/live/DOMAIN/fullchain.pem;
# ssl_certificate_key /etc/letsencrypt/live/DOMAIN/privkey.pem;
location / {
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_pass http://localhost:8384/;
proxy_read_timeout 600s;
proxy_send_timeout 600s;
The commented out part makes it use SSL, but the issue is the same either way.
