Hi, I managed to get a small trace of this on two clients. The connection will constantly connect and disconnect, switching between using relay and using direct connection. This did not happen before 0.13.x upgrade. Seems the only way to fix this is to stop both clients, rerun them, and hope it does not happen.
[TB344] is a remote Linux server. It’s port-forwarded, and has configured:
<listenAddress>relay://my.relay:443/?id=XXXXX</listenAddress><listenAddress>tcp://0.0.0.0:41666</listenAddress>
. I am using the default discovery server.
[3536Q] is my local Windows client. It’s not port-forwarded, and uses the same config as above, but using port 22666 instead.
0.12.x worked fine; 0.13.x (on .1 now, I never tried .0) seems to cause some weird loop in my setup. The loop is like “two clients connect using the relay, switch connection to direct TCP, close both connections and get really confused”?
Linux’s side of log:
[TB344] 14:21:54 INFO: Established secure connection to 3536QRY at IP.server:50011-IP.relay:443 (Relay (Server))
[TB344] 14:21:54 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:21:56 INFO: Connection to 3536QRY closed: switching connections
[TB344] 14:21:57 INFO: Established secure connection to 3536QRY at IP.server:41666-IP.windows:64548 (TCP (Server))
[TB344] 14:21:57 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:21:57 INFO: Connection to 3536QRY closed: read tcp IP.server:50011->IP.relay:443: use of closed network connection
[TB344] 14:21:57 INFO: Connection to 3536QRY closed: read tcp IP.server:41666->IP.windows:64548: use of closed network connection
[TB344] 14:22:00 INFO: Established secure connection to 3536QRY at IP.server:50014-IP.relay:443 (Relay (Server))
[TB344] 14:22:00 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:22:05 INFO: Connection to 3536QRY closed: switching connections
[TB344] 14:22:05 INFO: Connection to 3536QRY closed: write tcp IP.server:50014->IP.relay:443: write: connection reset by peer
[TB344] 14:22:06 INFO: Established secure connection to 3536QRY at IP.server:41666-IP.windows:54537 (TCP (Server))
[TB344] 14:22:06 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:22:06 INFO: Connection to 3536QRY closed: write tcp IP.server:41666->IP.windows:54537: use of closed network connection
[TB344] 14:22:15 INFO: Established secure connection to 3536QRY at IP.server:50019-IP.relay:443 (Relay (Server))
[TB344] 14:22:15 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:22:32 INFO: Connection to 3536QRY closed: switching connections
[TB344] 14:22:32 INFO: Connection to 3536QRY closed: write tcp IP.server:50019->IP.relay:443: write: broken pipe
[TB344] 14:22:38 INFO: Established secure connection to 3536QRY at IP.server:41666-IP.windows:51441 (TCP (Server))
[TB344] 14:22:38 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:22:39 INFO: Connection to 3536QRY closed: write tcp IP.server:41666->IP.windows:51441: use of closed network connection
[TB344] 14:23:32 INFO: Established secure connection to 3536QRY at IP.server:50028-IP.relay:443 (Relay (Server))
[TB344] 14:23:32 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:23:33 INFO: Connection to 3536QRY closed: switching connections
[TB344] 14:23:34 INFO: Established secure connection to 3536QRY at IP.server:41666-IP.windows:60295 (TCP (Server))
[TB344] 14:23:34 INFO: Device 3536QRY client is "syncthing v0.13.1" named "Windows-PC"
[TB344] 14:23:34 INFO: Connection to 3536QRY closed: read tcp IP.server:50028->IP.relay:443: use of closed network connection
[TB344] 14:23:34 INFO: Connection to 3536QRY closed: write tcp IP.server:41666->IP.windows:60295: write: connection reset by peer
Windows side of log:
[3536Q] 20:21:57 INFO: Established secure connection to TB3442P at 192.168.1.64:54280-IP.relay:443 (Relay (Client))
[3536Q] 20:21:57 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:21:59 INFO: Connection to TB3442P closed: switching connections
[3536Q] 20:21:59 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54280->IP.relay:443: use of closed network connection
[3536Q] 20:21:59 INFO: Established secure connection to TB3442P at 192.168.1.64:54281-IP.server:41666 (TCP (Client))
[3536Q] 20:21:59 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:21:59 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54281->IP.server:41666: wsasend: An existing connection was forcibly closed by the remote host.
[3536Q] 20:22:00 INFO: Detected 0 NAT devices
[3536Q] 20:22:02 INFO: Established secure connection to TB3442P at 192.168.1.64:54283-IP.relay:443 (Relay (Client))
[3536Q] 20:22:02 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:22:07 INFO: Connection to TB3442P closed: switching connections
[3536Q] 20:22:07 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54283->IP.relay:443: use of closed network connection
[3536Q] 20:22:07 INFO: Established secure connection to TB3442P at 192.168.1.64:54284-IP.server:41666 (TCP (Client))
[3536Q] 20:22:07 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:22:08 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54284->IP.server:41666: wsasend: An existing connection was forcibly closed by the remote host.
[3536Q] 20:22:17 INFO: Established secure connection to TB3442P at 192.168.1.64:54290-IP.relay:443 (Relay (Client))
[3536Q] 20:22:17 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:22:34 INFO: Connection to TB3442P closed: switching connections
[3536Q] 20:22:34 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54290->IP.relay:443: use of closed network connection
[3536Q] 20:22:35 INFO: Established secure connection to TB3442P at 192.168.1.64:54298-IP.server:41666 (TCP (Client))
[3536Q] 20:22:35 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:22:41 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54298->IP.server:41666: wsasend: An existing connection was forcibly closed by the remote host.
[3536Q] 20:23:34 INFO: Established secure connection to TB3442P at 192.168.1.64:54318-IP.relay:443 (Relay (Client))
[3536Q] 20:23:34 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:23:36 INFO: Connection to TB3442P closed: switching connections
[3536Q] 20:23:36 INFO: Established secure connection to TB3442P at 192.168.1.64:54319-IP.server:41666 (TCP (Client))
[3536Q] 20:23:36 INFO: Device TB3442P client is "syncthing v0.13.1" named "Linux-Server"
[3536Q] 20:23:36 INFO: Connection to TB3442P closed: read tcp 192.168.1.64:54318->IP.relay:443: use of closed network connection
[3536Q] 20:23:36 INFO: Connection to TB3442P closed: write tcp 192.168.1.64:54319->IP.server:41666: use of closed network connection
Hopefully I didn’t make it too confusing with obfuscating; IP.server is the global IP of the Linux server, IP.windows is the global IP of the Windows client, IP.relay is my relay’s IP, and 192.168.1.64 is the local IP of my Windows client.
Thanks, please let me know if there’s something more I can do to debug!
