Hello.
I’m setting up my first Syncthing v1.23.1 instance on Ubuntu 20.04LTS with Nginx as the proxy to an FQDN over https (i.e. externally viewable via a browser). I’m using the Syncthing apt setup as outlined here, running as a system service under systemd. I am using the service file from here with two changes on the ExecStart line to change the GUI address to non-localhost and enable logging to /var/log/syncthing.log:
ExecStart=/usr/bin/syncthing serve --no-browser --no-restart --logflags=0 --gui-address=0.0.0.0:8384 --logfile=/var/log/syncthing.log
I am using Nginx as a proxy via the http upstream, with basic htpasswd auth while I find my way and set things up properly. This proxy uses a hostname and port (port 707 in this case) as I run other proxies on the same host. I can access the Nginx proxy via https://hostname.example.com:707, I am prompted for the htpasswd login details (as expected), and I see the Syncthing GUI in my browser, with the correct machine hostname, a red ‘Danger’ box telling me about remote access without a password (expected) and a green ‘GUI Authentication’ box prompting me to set up authentication (expected).
After around 5 seconds, a modal appears asking if I want to report anonymous statistics. I say ‘Yes’ and immediately I see a red ‘Connection Error’ with the following text:
Syncthing seems to be experiencing a problem processing your request. Please refresh the page or restart Syncthing if the problem persists.
If I leave the modal in place without clicking, the browser console throws two errors:
[Error] Failed to load resource: the server responded with a status of 404 () (customicons.css, line 0)
[Error] Failed to load resource: the server responded with a status of 501 () (upgrade, line 0)
Then, the following errors are appended to the console:
[Error] Failed to load resource: The operation couldn’t be completed. (kCFErrorDomainCFNetwork error 303.)
If I then click ‘Yes’ from the modal, which triggers the ‘Connection Error’ modal, the following errors appear in the console:
[Error] Failed to load resource: the server responded with a status of 403 () (config, line 0)
I’ve opened ports using ufw:
$ sudo ufw status
Status: active
To Action From
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
707/tcp ALLOW Anywhere
22000/tcp ALLOW Anywhere
22000/udp ALLOW Anywhere
syncthing ALLOW Anywhere
syncthing-gui ALLOW Anywhere
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
707/tcp (v6) ALLOW Anywhere (v6)
22000/tcp (v6) ALLOW Anywhere (v6)
22000/udp (v6) ALLOW Anywhere (v6)
syncthing (v6) ALLOW Anywhere (v6)
syncthing-gui (v6) ALLOW Anywhere (v6)
Edit: I would check the logs, but…there are none, despite the path being set in the service file.
…and now I’m scratching my head as to what else I need to do to get this firing on all cylinders properly.
What have I missed?
Thank for your reading, and your considerations in any advice & feedback.
