Ok so I have it set up fine syncing a desktop computer and a laptop, but I seem to have made an error configuring the rasperry pi. I get two errors, (which may not be related). At the moment the RPI is considered offline by the other two computers.
Syncthing seems to be down, or there is a problem with your Internet
connection. Retrying…
and
Global UDP discovery (udp6://announce-v6.syncthing.net:22026): listen udp6 :0: address family not supported by protocol; trying again in 1m0s
I wonder if anyone could help me troubleshoot this connection error? Thanks!
On issue 1 - Looks like its maxing out the CPU on the RPI - could it be an issue with an initial scan etc. taking a while? And it is regularly “seen” by the other two computers according to the GUI. So perhaps its an issue with the CPU overload? It looks like it does a bit of syncing, then crashes, then gets going again. I guess it may settle down later, but it may be a bug rather than a config error on my part?
On issue 2 - I deleted the udb6 line from the config, and now do not have that error… So I think they are definitely unrelated, but I still dont know what the problems are!
