Connected (Unused)
Hello, I have installed syncthing on a proxmox container with a helper script (Proxmox VE Helper-Scripts). There are notes here that I want to sync with my desktop PC (Linux) and an Android phone. Everything seems to be working - the devices are connected, but are not synced. Message: Connected (not used). Can someone help me?
This means that you haven’t shared any folders with those devices yet. You can do this either in the each device’s settings or the folder settings.
Do you mean a samba share under linux? on the server?
Please check https://docs.syncthing.net/intro/getting-started.html if you haven’t already. You need to share the folders from one side and accept them on the other side.
i found the solution. here it is:
these hooks must be set
everything works fine now :slight_smile:
