Hi, how does Syncthing handle conflicts? Maybe there’s documentation about this but I couldn’t find any.
What happens for example if two nodes are offline for a period of time and edits the same file and then connects to a central node for syncing?
Currently, it seems that one of the conflicted files is lost. I’m not sure which one.
Conflict handling is discussed here: https://github.com/syncthing/syncthing/issues/220
The newest version of the file wins.
I also would like to see a solution to conflicted files. Both Dropbox and Wuala make a copy of the conflicted files adding a sufix for quick recognition. Do you plan to add something like that?
Also see this thread: https://pulse-forum.ind.ie/t/does-old-ever-clobber-new/1242
I would like to suggest an (optional) renaming feature if a conflict (e.g. file.jpg) is detected e.g. file (conflict-1).jpg, file (conflict-2).jpg - this way you never lose any files if have seen this in other multi-host sync programs and it works really well for daily use
