Hi, I’m considering syncthing for this scenario, a central repository on which we will record videos, I need to maintain synchronized some clients (no more than ten, but more realistic is five). The central repository will be the master, the others only clients. The master will be GNU/Linux, clients will be Windows *& or 10, I do not know by now)
I must do all configuration without using the web gui, it will be disabled on both master and clients, so I need to create the configuration xml using bash/perl script and then copy them on the machines.
How can I force synchronization from the master to the client using commandline?
How can I generate the id of the clients using commandline if I need to? I read the description of the ID, if I understand fine, the ID is based on the ssl certificate, so I have to create a ssl certificate for every clients and the server and then apply the procedure. Is there a command to create the id starting from a certificate?
Thanks, Pietro.
