While trying the new MaxConcurrentWrites setting, I noticed that the config is not saved after setting the option in all the folders and clicking save.
In the Syncthing config folder I noticed that “config.xml” is dated 7th April, on top row it says “version 30”. I then restarted Syncthing but the old date remained. I changed MaxConcurrentWrites again, this time it was saved.
Any ideas what has happened here?
How can I make sure the config.xml has all the necessary fields?
Thanks for the suggestions, I don’t use proxies.
I only checked the Syncthing console log, but not the browser console - will keep that in mind for next time.
