I am referring to this: http://screencast.com/t/xQzPvvsQ Is that something still to be introduced?
Hit “Edit”. It should probably default to on, but it’s annoyingly tricky to distinguish between an option being false
by default and false
because the user turned it off.
Should just enable it on all nodes when it detects the previous installation was v0.8 (v0.8 uses compression by default).
I can’t find an option for compression, hence my question:
http://screencast.com/t/D9WR6ZD8xlUU http://screencast.com/t/YezBFxLTskY
Where else is that option hiding?
In the node config.
oops! :-/ my bad, sorry again.
