I just got my first docker container up and running, following the instruction here
I noticed that syncthing has just updated to 1.22.1 so i thought i would try to update it.
The procedure seems to be to downlaod the new image (which i have) and then settings/duplicate.
I started up the new container but everything is reset - there are no shares and it doesnt knwo about the gui password.
I assume my settings are not being saved correctly.
Following the setup instructions i have a /docker/syncthing folder but there is nothing in it - should there be?
Any help would be appeciated. I am a real Docker newb
