I have setup a private discovery and relay server on a network. Everything appears to be working. I have Syncthing clients on different networks and on the same network. They are all able to send data back and forth.
However, the clients on the LAN appear to be sending data through the relay sever. On the Web Interface, the Address for the Remote Device shows the relay server’s address and port.
I have a local DNS entry and a public DNS entry for relay.xxxx.com and discovery.xxxx.com that points to a local IP and a public IP address.
Local Discovery appears to be working but still goes through relay instead of the local IP.
Log shows:
- discover: Received local announcement from 10.20.1.XXXX:64901 for 73IMOSV-AMSZALN-UXBY7E2-DLOEL6F-IZNPFFF-BPTTHQ5-SWOY4AC-XXXX
- discover: Registering addresses for 73IMOSV-AMSZALN-UXBY7E2-DLOEL6F-IZNPFFF-BPTTHQ5-SWOY4AC-XXXX
- discover: Accepted address relay://relay.XXXX.com:22067 verbatim
Any help is appreciated. Thanks
