CLI Shutdown
Some entries in this forum suggest to quit syncthing via TERM(15) signal. Comparing both activities shows different output:
  1. SHUTDOWN VIA WEBUI
    [XYZWQ] 14:53:14 INFO: Access the GUI via the following URL: http://127.0.0.1:qwertz/
    [XYZWQ] 14:53:21 INFO: Shutting down
    [XYZWQ] 14:53:21 INFO: TCP listener ([::]:qwertz+1) shutting down
    [XYZWQ] 14:53:31 INFO: Exiting
  2. pkill -TERM syncthing
    [XYZWQ] 14:52:28 INFO: Access the GUI via the following URL: http://127.0.0.1:qwertz/
    [monitor] 14:52:35 INFO: Signal 15 received; exiting
  3. JUST FOR REFERENCE: pkill -HUP syncthing
    [5R3WQ] 14:43:58 INFO: Access the GUI via the following URL: http://127.0.0.1:qwertz/
    [monitor] 14:44:06 INFO: Signal 1 received; restarting
    [XYZWQ] 14:44:06 INFO: TCP listener ([::]:qwertz+1) shutting down
    [XYZWQ] 14:44:16 INFO: Exiting
    [monitor] 14:44:16 INFO: Syncthing exited: exit status 3
    [monitor] 14:44:17 INFO: Starting syncthing
So, pkill -TERM looks like the hard way. Is this really the right way or rephrased : does ST perform the shut down correctly anyway?
Thanks!
You found a bug in the monitor: When intercepting TERM it kills the main syncthing process, instead of signalling it to stop (i.e. passing TERM on). Could you please open an issue on github.
pkill is anyway a bit non-deterministic when Syncthing is running with the monitor, as pkill will hit both processes.
