Is there a CLI version of ST for android. I do not mind using command line to get my stuff synced if interface stuff is harder to debug. I would be more than happy to have a debuggable ST cli.
thanks
thanks
If you have root, you can just cd into /data/data/com.nutomic.syncthingandroid
and run ./libs/libsyncthing.so
. Otherwise, you could download a syncthing binary and extract it to sdcard and run it.
But generally, command line isn’t really a thing on Android, so I don’t see how this could be integrated into the app.
Ok I am running the cli version. It is all good accept that the “save” button in creating repo page in the browser is grayed out so I cannot add a repository ;(
I am perfectly fine using the cli version considering that we it already comes with a web server.
This is a bug. Upgrade to v0.9.8 or fill in a rescan interval (where it looks like it already says “60”).
