When running Syncthing inside a Docker container, it’s necessary to use some sort of supervisory process manager (like supervisord, upstart, runit, etc) as the “primary” process. Otherwise if Syncthing is the only/primary process running and it restarts, the container instantly stops when Syncthing does.
I’m sure I’m not asking this right, but is there a way to maintain part of the Syncthing process running while reloading the parts (new settings, nodes, etc.) that require the restart?
It’s not a big deal if that’s impossible or not desired! Docker seems to be taking off, and it would just be nice to minimize the number processes running per container. I can probably just use the systemd “Restart=always” directive to restart the container when it stops (as long it’s being managed by some external container manager like systemd or the equivalent).
Thanks, Scott
