Hi I have a computer that I have used to share a lot off shared folders with other computers but now I want to change my location off the files on my computer how do I go about doing this with snychthing
Anyone know how I can do this ?
Option 1 (most fail-save):
- Remove the folders from syncthing
- Move the folders on disk
- Readd the folder in syncthing, using the same id’s and settings as previously
Option 2:
- Stop syncthing
- Move folders on disk
- Open syncthing’s config.xml and modify the
path
attribute of the<folder>
XML entries. - Save the file and restart syncthing
-> Note that for option 2, all folder (meta-)data should stay the same to avoid unexpected results or even data loss. Make a backup first.
With Option 2 I would additionally recommend to set the folder to “receive-only” and switch that back to send-receive once the initial scan and index exchange are done and everything looks good and dandy (still not failsafe though, as is everything else -> backups!).
I usually do a variant of that and set a known-good device to send-only prior to shady manoeuvres. Then that place is protected, and there’s a handy override there in case of havoc.
