I have many clients pointing to a single folder on my server. I’d like to move that folder somewhere else, but that would entail changing the Syncthing path.
I assume it’s not editable in the GUI for obvious reasons as you could probably really muck things up doing this. I’ll edit the config.xml directly.
Given that I’m moving the folder and its contents in their entitreity, and plan to shut down Syncthing during the move, are there any other gotchas I might run into?
Data is backed up, obviously,
Thanks!
