Changes from PC not Pushed to Android
Hi, i just setup SyncThing on PC and Android.
On PC I have KeePassXC and KeeShare enabled. The KeeShare-KDBX File goes to the synched Folder with the phone.
If i make a change on pc, the File gets updated - i see it in KeePass and also in the file Spec.
But it gets not synched to my Mobile… I wait a while, open the db on the phone but still have the old version.
If i Make changes in phone the Updates get reflected to pc very fast.
Any Idea why Push from PC doesnt Work properly? If i do Synch on PC in SyncThing manually, I´ll see changes made on the pc in my phone.
Thanks in advance for your help, i hope i just miss something very small - tripple checked my two tutorials i followed. Couldn´t find the issue myself sofar.
the second tutorial i followed is:
I also changend now to Updates in Wifi only (with static IP) but other than in this tutorial i still use Send & Receive
Are you using KeePassXC’s KeeShare feature to export only specific records to your Android device?
Hey - thanks for your reply. I just think i found out. On PC Side it just takes a bit longer than on mobile side to push changes.
