certificate issue again
Hi, can’t update from 2.0.8 to 2.0.9. I reinstalled ca-certificates already - still getting the error. Before I got an error regarding false hash values.
error: Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification.
Any recipe what to do? I’m on LM and Pop_OS
What command is giving you that error? Give more context, please.
Oh sorry forgot to mention this: I simply wanted to update with the package manager, added syncthing to sources as described in the documentation. Worked till 2.0.8.
Please post your source file and the output of
sudo apt update
deb [signed-by=/etc/apt/keyrings/syncthing-archive-keyring.gpg] https://apt.syncthing.net/ syncthing stable-v2 ## X-Repolib-Name: syncthing # X-Repolib-ID: syncthing
apt update Get:13 ``https://apt.syncthing.net`` syncthing InRelease [24,2 kB]
w/ - -upgradeable I get syncthing/syncthing 2.0.9 amd64 [upgradable from: 2.0.8]
I set also this preference - maybe that’s related?
printf “Package: *\nPin: origin ``apt.syncthing.net``\nPin-Priority: 990\n” | sudo tee /etc/apt/preferences.d/syncthing.pref
Any idea what I could do, I’m still facing the issue. Thanks!
You haven’t posted the output you were asked for, at least not in a way I can make sense of. That said, I would guess you just have old or lacking certificates installed. Make sure you’re running the latest version of whatever Debian/Ubuntu it is you’re running?
oh sorry, could you explain how to get what you need? I’m on Pop!_OS 22.04 LTS – everything is updated to the latest afaik. I reinstalled ca-certificates as well
@thob you can try to check in command line something like
curl --tlsv1.3 -v https://discovery-lookup.syncthing.net:443/
if system certificates are OK, it should answer with 404.
getting
Trying 5.9.87.175:443...
* Connected to discovery-lookup.syncthing.net (5.9.87.175) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CAfile: /etc/ssl/certs/ca-certificates.crt
*  CApath: /etc/ssl/certs
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256
* ALPN, server accepted to use h2
* Server certificate:
*  subject: CN=discovery-lookup.syncthing.net
*  start date: Aug 10 11:30:30 2025 GMT
*  expire date: Nov  8 11:30:29 2025 GMT
*  subjectAltName: host "discovery-lookup.syncthing.net" matched cert's "discovery-lookup.syncthing.net"
*  issuer: C=US; O=Let's Encrypt; CN=R11
*  SSL certificate verify ok.
* Using HTTP2, server supports multiplexing
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x59dca5fd69f0)
> GET / HTTP/2
> Host: discovery-lookup.syncthing.net
> user-agent: curl/7.81.0
> accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* Connection state changed (MAX_CONCURRENT_STREAMS == 250)!
< HTTP/2 404
< content-type: text/plain; charset=utf-8
< date: Fri, 26 Sep 2025 19:14:30 GMT
< retry-after: 970
< x-content-type-options: nosniff
< content-length: 10
Not Found
* Connection #0 to host discovery-lookup.syncthing.net left intact
system certificates seems ok, I have no idea what is wrong, sorry.
We still don’t know what is going wrong exactly. It says that 2.0.9 is available, so just upgrade it? Whatever goes wrong in that step, we need to see what you entered and what the console responded.
If it’s about some certificate not being accepted, please describe your network environment. It might be some corporate “security” appliance breaking the https connection for example.
you were right, I was checking firewall and dns, nextdns blocked it, it seems. Very odd. Never happend before. Very likely that a list added syncthing as bad actor, hmm. But: I’m on 2.0.10 as of now. Thanks
