When I click the “Add Folder” or “Add Remote Device” buttons on my SyncThing home page [v0.14.7, Windows 64 bit, viewed at http://127.0.0.1:8384/ in Google Chrome (with extensions disabled) and in Firefox], no dialog appears. (The buttons ‘depress’ but no popup appears.) Other buttons - such as to edit an existing folder - work as expected. I imagine this is a bug but is there something straightforward I’m overlooking?
Check javascript console for errors.
Also try a different browser.
No errors visible in Javascript console, and no notifications appear on clicking the button. Though in fact “nothing happens” is not quite accurate: Chrome reports “Waiting for 127.0.0.1” as an overlay to the webpage in the bottom corner, and the Favicon is replaced with a “loading” swirly circle.
I’ve tried both Chrome and Firefox, are there other browsers that you would recommend I try?
Sounds like a deadlock, try sending a SIGQUIT to the process to get the stacktraces to stdout
As Syncthing was running with the --no-console option, I terminated it using Ctrl-Alt-Esc and re-launched syncthing.exe through Windows Explorer. This seems to have resolve the issue – should have thought to try this sooner, I suppose. Thanks for your help!
