I set up syncthing with a raspberry pi, 2 laptop, tablet and a mobile phone. Everything works like a charm when I am in my wifi network.
When I am outside my network I can not connect from my phone to my raspberry.
On my raspberry “global discovery” an UPnP ist activated. I can see in my router that UPnP works.
TCP, 58916, raspberry-pi, 192.168.178.155, 22000
What is wrong with my configuration?
Here my configuration on my raspberry.
<listenAddress>0.0.0.0:22000</listenAddress>
<globalAnnounceServer>udp4://announce.syncthing.net:22026</globalAnnounceServer>
<globalAnnounceEnabled>true</globalAnnounceEnabled>
<localAnnounceEnabled>true</localAnnounceEnabled>
<localAnnouncePort>21025</localAnnouncePort>
<localAnnounceMCAddr>[ff32::5222]:21026</localAnnounceMCAddr>
<maxSendKbps>0</maxSendKbps>
<maxRecvKbps>0</maxRecvKbps>
<reconnectionIntervalS>60</reconnectionIntervalS>
<startBrowser>true</startBrowser>
<upnpEnabled>true</upnpEnabled>
<upnpLeaseMinutes>0</upnpLeaseMinutes>
<upnpRenewalMinutes>30</upnpRenewalMinutes>
<urAccepted>0</urAccepted>
<urUniqueID></urUniqueID>
<restartOnWakeup>true</restartOnWakeup>
<autoUpgradeIntervalH>12</autoUpgradeIntervalH>
<keepTemporariesH>24</keepTemporariesH>
<cacheIgnoredFiles>true</cacheIgnoredFiles>
<progressUpdateIntervalS>5</progressUpdateIntervalS>
<symlinksEnabled>true</symlinksEnabled>
Have you actually tried connecting to that port from the outside, to see if it gets mapped correctly?
I mean from the outside. Basically, is port 58916 being correctly routed by your router?
Also, you might want to run STTRACE=discovery to see if the outside node gets the correct IP for the router.
I really appreciate your help. But I am just an “user” and dont really know what you mean.
I will try a connection from outside with my laptop tomorrow.
Just a question. Which would be a manual port forwarding setup, without UPnP.
from port xyz1 to port xyz2 on raspberry port 22000. What would be “xyz1” and “xyz2”
Hi again,
I check with my laptop (tethering via mobile) and it works. It can connect to my raspberry.
But the mobile can not.
Here is the mobile config found in
/data/data/com.nutomic.syncthingandroid/files/config.xml
< options>
< listenAddress>0.0.0.0:22000< /listenAddress>
< globalAnnounceServer>upd4://announce.syncthing.net:22026< /globalAnnounceServer>
< globalAnnounceEnabled>true< /globalAnnounceEnabled>
< localAnnounceEnabled>true< /localAnnounceEnabled>
< localAnnouncePort>21025< /localAnnouncePort>
< localAnnounceMCAddr>[ff32::5222]:21026< /localAnnounceMCAddr>
< maxSendKbps>0< /maxSendKbps>
< maxRecvKbps>0< /maxRecvKbps>
< reconnectionIntervalS>60< /reconnectionIntervalS>
< startBrowser>true< /startBrowser>
< upnpEnabled>false< /upnpEnabled>
< upnpLeaseMinutes>0< /upnpLeaseMinutes>
< upnpRenewalMinutes>30< /upnpRenewalMinutes>
< urAccepted>-1< /urAccepted>
< urUniqueID>< /urUniqueID>
< restartOnWakeup>true< /restartOnWakeup>
< autoUpgradeIntervalH>12< /autoUpgradeIntervalH>
< keepTemporariesH>24< /keepTemporariesH>
< cacheIgnoredFiles>true< /cacheIgnoredFiles>
< progressUpdateIntervalS>5< /progressUpdateIntervalS>
< symlinksEnabled>true< /symlinksEnabled>
< / options>
< / configuration>
How can I run “STTRACE=net,discover syncthing &> syncthing.log” on my android device?
I think you need to set the debug options from the UI and then download some log inspector (if your device is rooted), otherwise use adb (google logcat android howto)
I found the solution.
Global Discovery did not work correct.
I just had to change “udp4://announce.syncthing.net:22026” to “udp4://194.126.249.5:22026” on my android devices. Now it works!
calmh
(Jakob Borg)
December 12, 2014, 11:29am
9
That should already have been the case if you were running the Android app? But this was homebrew maybe?
