Default has a rescan interval. Can I set different intervals on various subfolders?
Also, I’d rather not even see default itself, but only the subfolders. Can \default be hidden?
There’s no such thing as subfolders - I assume you mean normal disk folders inside of default. Those don’t get individual settings. But you can remove default and add folders as you see fit, with individual scan intervals.
Yes, that’s what I meant. “Inside of” means “subfolder of”.
Since you’ve confirmed that I can delete \default and have it disappear from the display, I’ll do that. Thanks for the tip.
