Can consider QNAP device? T-212P and so on;
UP~~~~~~~~~~~~~~~~~~~~ Is the official support?
There are a few threads about QNAP installations here on the forum. Did you try a search?
I have found, unfortunately, the latest version is: v0.10.29
v0.10.29 is almost the latest version. The package I installed was initially a v0.10.24 wherein Syncthing autoupdates itself (on Qnap club, from Father Mande), so I think that you should be fine with the one you found.
Mine comes from the first link you listed, and works well (My NAS is a small one, I got very high CPU load while indexing, it took some hours, but then it settled and everything is OK since then).
