I’ve had this problem with several PRs now, but never got it working in order to test how my own GUI changes affect translations. Now asking for help here to troubleshoot.
After running the translation script, the gui/default/assets/lang/lang-en.json
file is always completely empty. It seems that redirecting the output of translate.go
to lang-en-new.json
fails, although the command itself does output something. This is the CLI output, maybe the warning have something to do with it?
go run build.go translate
2021/05/26 16:22:22 Untranslated text node (editFolderModalView.html):
2021/05/26 16:22:22 <p class="help-block">
<span translate ng-if="folderEditor.externalCommand.$valid || folderEditor.externalCommand.$pristine">See external versioning help for supported templated command line parameters.</span>
<span translate ng-if="folderEditor.externalCommand.$error.required && folderEditor.externalCommand.$dirty">The path cannot be blank.</span>
</p>
</div>
<div class="form-group" ng-if="internalVersioningEnabled()" ng-class="{'has-error': folderEditor.cleanupIntervalS.$invalid && folderEditor.cleanupIntervalS.$dirty}">
<label translate for="cleanupIntervalS">Cleanup Interval</label>
<div class="input-group">
<input name="cleanupIntervalS" id="cleanupIntervalS" class="form-control text-right" type="number" ng-model="currentFolder._guiVersioning.cleanupIntervalS" required="" min="0" max="31536000" aria-required="true" />
<div class="input-group-addon" translate>seconds</div>
</div>
<span translate ng-if="folderEditor.cleanupIntervalS.$valid || folderEditor.cleanupIntervalS.$pristine"class="help-block">The interval, in seconds, for running cleanup in the versions directory. Zero to disable periodic cleaning.</span>
<span translate ng-if="folderEditor.cleanupIntervalS.$error.required && folderEditor.cleanupIntervalS.$dirty">The cleanup interval cannot be blank.</span>
<span translate ng-if="folderEditor.cleanupIntervalS.$error.min && folderEditor.cleanupIntervalS.$dirty">The interval must be a positive number of seconds.</span>
</p>
</div>
</div>
<div ng-if="!editingDefaults" id="folder-ignores" class="tab-pane">
<p translate>Enter ignore patterns, one per line.</p>
<div ng-class="{'has-error': ignores.error != null}">
<textarea class="form-control" rows="5" ng-model="ignores.text" ng-disabled="ignores.disabled">
